[Mapserver-users] limiting query results
Ryan, Adam
ARyan at co.linn.or.us
Thu Mar 13 14:52:30 EST 2003
This message is in MIME format. Since your mail reader does not understand
this format, some or all of this message may not be legible.
------_=_NextPart_001_01C2E99A.14F74520
Content-Type: text/plain;
charset="iso-8859-1"
I'm already doing this to some extent, but a box in the rural areas may
return a couple dozen properties, where the same box at the same scale in an
urban area bogs down.
Adam
-----Original Message-----
From: Fawcett, David [mailto:David.Fawcett at state.mn.us]
Sent: Thursday, March 13, 2003 11:32 AM
To: mapserver-users at lists.gis.umn.edu; 'Ryan, Adam'
Subject: RE: [Mapserver-users] limiting query results
For the instance of the user selecting the whole county with the box, could
you use scale-dependent layers so they don't have the option to query the
whole county.
I am sure that there is a more elegant solution, but this could prevent the
crash you are describing.
David.
David J. Fawcett
GIS / Databases
MN Office of Environmental Assistance
520 Lafayette Rd N
St. Paul, MN 55155
651.215.0200
> From: Ryan, Adam[SMTP:ARyan at co.linn.or.us]
> Sent: Thursday, March 13, 2003 1:02 PM
> Subject: [Mapserver-users] limiting query results
> Dear List,
> I'm resending this because I can't find a cgi (not mapscript) solution.
> I want to limit the number of records returned by an NQUERY or and
ITEMNQUERY, or the number of times mapserv sends the layer template. If the
user makes a box around the whole county, or searches by [STREETNAME] =~
/ST/, for example, mapserv easily and quickly renders the image, but then
spits out the layer template many thousands of times and ultimately crashes
the browser.
> I can monitor the [rn] and take steps using javascript, but I can't stop
mapserv from spitting out all the instances of the template.
> I can't use MAXFEATURES because that limits the number of records that are
searched, not the number returned.
> Any ideas?
> Adam Ryan
> Linn County
Content-Type: text/html;
Content-Transfer-Encoding: quoted-printable
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 3.2//EN">
<HTML>
<HEAD>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Diso-8859-1">
<META NAME=3D"Generator" CONTENT=3D"MS Exchange Server version =
5.5.2653.12">
<TITLE>RE: [Mapserver-users] limiting query results</TITLE>
</HEAD>
<BODY>
<BR>
<P><FONT SIZE=3D2>I'm already doing this to some extent, but a box in =
the rural areas may return a couple dozen properties, where the same =
box at the same scale in an urban area bogs down.</FONT></P>
<P><FONT SIZE=3D2>Adam</FONT>
</P>
<P><FONT SIZE=3D2>-----Original Message-----</FONT>
<BR><FONT SIZE=3D2>From: Fawcett, David [<A =
HREF=3D"mailto:David.Fawcett at state.mn.us">mailto:David.Fawcett at state.mn.=
us</A>]</FONT>
<BR><FONT SIZE=3D2>Sent: Thursday, March 13, 2003 11:32 AM</FONT>
<BR><FONT SIZE=3D2>To: mapserver-users at lists.gis.umn.edu; 'Ryan, =
Adam'</FONT>
<BR><FONT SIZE=3D2>Subject: RE: [Mapserver-users] limiting query =
results</FONT>
</P>
<BR>
<P><FONT SIZE=3D2>For the instance of the user selecting the whole =
county with the box, could you use scale-dependent layers so they don't =
have the option to query the whole county. </FONT></P>
<P><FONT SIZE=3D2>I am sure that there is a more elegant solution, but =
this could prevent the crash you are describing. </FONT>
</P>
<P><FONT SIZE=3D2>David.</FONT>
</P>
<BR>
<P><FONT SIZE=3D2>David J. Fawcett</FONT>
<BR><FONT SIZE=3D2>GIS / Databases</FONT>
</P>
<P><FONT SIZE=3D2>MN Office of Environmental Assistance</FONT>
<BR><FONT SIZE=3D2>520 Lafayette Rd N</FONT>
<BR><FONT SIZE=3D2>St. Paul, MN 55155</FONT>
<BR><FONT SIZE=3D2>651.215.0200</FONT>
</P>
<BR>
<P><FONT SIZE=3D2>> ----------</FONT>
<BR><FONT SIZE=3D2>> From: =
Ryan, =
Adam[SMTP:ARyan at co.linn.or.us]</FONT>
<BR><FONT SIZE=3D2>> Sent: =
Thursday, March 13, 2003 =
1:02 PM</FONT>
<BR><FONT SIZE=3D2>> To: =
mapserver-users at lists.gis.umn.edu</FONT>
<BR><FONT SIZE=3D2>> Subject: =
[Mapserver-users] limiting query results</FONT>
<BR><FONT SIZE=3D2>> </FONT>
<BR><FONT SIZE=3D2>> Dear List, </FONT>
<BR><FONT SIZE=3D2>> I'm resending this because I can't find a cgi =
(not mapscript) solution. </FONT>
<BR><FONT SIZE=3D2>> I want to limit the number of records returned =
by an NQUERY or and ITEMNQUERY, or the number of times mapserv sends =
the layer template. If the user makes a box around the whole =
county, or searches by [STREETNAME] =3D~ /ST/, for example, mapserv =
easily and quickly renders the image, but then spits out the layer =
template many thousands of times and ultimately crashes the =
browser.</FONT></P>
<P><FONT SIZE=3D2>> </FONT>
<BR><FONT SIZE=3D2>> I can monitor the [rn] and take steps using =
javascript, but I can't stop mapserv from spitting out all the =
instances of the template.</FONT></P>
<BR><FONT SIZE=3D2>> I can't use MAXFEATURES because that limits the =
number of records that are searched, not the number returned. </FONT>
<BR><FONT SIZE=3D2>> Any ideas? </FONT>
<BR><FONT SIZE=3D2>> Adam Ryan </FONT>
<BR><FONT SIZE=3D2>> Linn County </FONT>
</P>
</BODY>
</HTML>
------_=_NextPart_001_01C2E99A.14F74520--
