[Mapserver-users] ArcExplorer 4.0.1 WMS Client
Daniel Morissette
morissette at dmsolutions.ca
Thu Mar 13 15:26:08 EST 2003
Daryl Herzmann wrote:
> Here is the error from ArcExplorer
> tokenizer exception; nested exception is;
> com.esri.axl.indiana.sxt.XmlTokenizerException: unexpected end of stream
> (state=71)
> at com.esri.axl.indiana.sxt.XmlTokenizer.next(XmlTokenizer.java:310)
> PS. I can query the mapserver from the Cubewerx site...
> PSS. This is mapserver 3.6.4 on RH Linux 7.3
I'm not sure if that's the problem, but your onlineResource URL ends
with '&' which is invalid in an XML entity and most validating XML
parsers will complain about that:
<Get><OnlineResource xlink:href="http://.../wfs/wfs.map&"/></Get>
This is handled (encoded) automatically in 3.7, but I didn't want to
backport the fix to 3.6 to avoid causing other side-effects to already
working servers. What you can do is replace the last "&" with "&"
in your onlineresource metadata. Remember to take it out when you will
upgrade to 3.7 otherwise you'll end up with "&amp;" in your
MapServer 3.7 capabilities.
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
