[Mapserver-users] ArcExplorer 4.0.1 WMS Client
Daryl Herzmann akrherz at iastate.edu
Thu Mar 13 16:25:55 EST 2003
Hi Daniel!
Thanks for the note.  We are almost there :)  Now I get this from
ArcExplorer
###### Start to WMS getCapabilities in GETWMSService class version=null
*********** realVersion is = none
*********** Version is = null
This version is not supported
******* Exception for WMS: null
java.lan.NullPointerException
Looking at the difference between versions from the MIT Ortho and
mapserver, I see
from mapserver:
<WMT_MS_Capabilities version="1.1.0" updateSequence="0">
from Ortho:
<WMT_MS_Capabilities version="1.0.0">
Do I need to upgrade to 3.7 dev to get 1.1.1 support?  Or should I
downgrade to 1.0.0 to get this to work?  Looking at the Extension FAQ,
perhaps this beast only supports 1.0.0 and 1.1.1 ??
Daryl
On Thu, 13 Mar 2003, Daniel Morissette wrote:
>Daryl Herzmann wrote:
>> Here is the error from ArcExplorer
>> tokenizer exception; nested exception is;
>> com.esri.axl.indiana.sxt.XmlTokenizerException: unexpected end of stream
>> (state=71)
>>     at com.esri.axl.indiana.sxt.XmlTokenizer.next(XmlTokenizer.java:310)
>> PS.  I can query the mapserver from the Cubewerx site...
>> PSS. This is mapserver 3.6.4 on RH Linux 7.3
>I'm not sure if that's the problem, but your onlineResource URL ends
>with '&' which is invalid in an XML entity and most validating XML
>parsers will complain about that:
>   <Get><OnlineResource xlink:href="http://.../wfs/wfs.map&"/></Get>
>This is handled (encoded) automatically in 3.7, but I didn't want to
>backport the fix to 3.6 to avoid causing other side-effects to already
>working servers.  What you can do is replace the last "&" with "&amp;"
>in your onlineresource metadata.  Remember to take it out when you will
>upgrade to 3.7 otherwise you'll end up with "&amp;amp;" in your
>MapServer 3.7 capabilities.
 * Daryl Herzmann (akrherz at iastate.edu)
 * Program Assistant -- Iowa Environmental Mesonet
 * http://mesonet.agron.iastate.edu
