[Mapserver-users] Transparency values - confusion
randy james rjames57 at yahoo.com
Thu Mar 13 16:11:10 EST 2003
Hi
Mine is like this:
<!-- MapServer version 3.7 (development) OUTPUT=PNG
OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ SUPPORTS=TTF
SUPPORTS=WMS_SERVER SUPPORTS=GD2_RGB INPUT=EPPL7
INPUT=JPEG INPUT=POSTGIS INPUT=GDAL INPUT=SHAPEFILE
IMAGETYPE png24
 OUTPUTFORMAT
    NAME png24
   MIMETYPE "image/png"
    DRIVER "GD/png"
   IMAGEMODE PC256
  END
layer
    data "92i_mod"
    name 'aoa'
    status off
    type polygon
    transparency 30
    # 1 class #none
    class
    name 'aoa_mod'
      color 255 255 0
    end
  end
Cheers
Randy
>  >> I've noticed the same thing in 3.7.  When I
> switch
>  >> between 8-bit and
>  >> 24-bit output I have to invert my transparency
>  >> values (i.e., change 25
>  >> to 75 and vice-versa) to get the same effect.
> randy james wrote:
> > I have been testing outputformat and switching
> between
> > PNG and PNG24 and never had to change anything.
> Have
> > you been using outputformat?
> Yep, I'm using OUTPUTFORMAT for both.  I can toggle
> between the
> imagetypes and see the transparency change on a
> polygon layer when I
> refresh the map.
> #IMAGETYPE png8
> IMAGETYPE png24
> OUTPUTFORMAT
>    NAME png8
>    DRIVER "GD/PNG"
>    IMAGEMODE PC256
>    FORMATOPTION "INTERLACE=ON"
> END
> OUTPUTFORMAT
>    NAME png24
>    DRIVER "GD/PNG"
>    IMAGEMODE RGB
> END
> LAYER
>    NAME boundary
>    STATUS ON
>    TYPE POLYGON
>    DATA sevbnd83
>    TRANSPARENCY 35
>    CLASS
>      NAME "Boundary"
>      OUTLINECOLOR 110 110 110
>      COLOR 243 248 245
>    END
> END
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
__________________________________________________
Do you Yahoo!?
Yahoo! Web Hosting - establish your business online
http://webhosting.yahoo.com
