[Mapserver-users] Transparency values - confusion
Dylan Keon
keon at nacse.org
Thu Mar 13 16:19:07 EST 2003
I'm pretty sure you're not getting 24-bit output with this, since you're
using IMAGEMODE PC256. This may be why you're not noticing a change in
transparency. Regular 8-bit output defaults to PC256. Try IMAGEMODE
RGB in your png24 entry and see if it makes a difference.
See http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?OutputFormat for more
info on IMAGEMODE.
--Dylan
randy james wrote:
> Hi
> Mine is like this:
> <!-- MapServer version 3.7 (development) OUTPUT=PNG
> OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ SUPPORTS=TTF
> SUPPORTS=WMS_SERVER SUPPORTS=GD2_RGB INPUT=EPPL7
> INPUT=JPEG INPUT=POSTGIS INPUT=GDAL INPUT=SHAPEFILE
> IMAGETYPE png24
> OUTPUTFORMAT
> NAME png24
> MIMETYPE "image/png"
> DRIVER "GD/png"
> IMAGEMODE PC256
> END
> layer
> data "92i_mod"
> name 'aoa'
> status off
> type polygon
> transparency 30
> # 1 class #none
> class
> name 'aoa_mod'
> color 255 255 0
> end
> end
> Cheers
> Randy
>> >> I've noticed the same thing in 3.7. When I
>>switch
>> >> between 8-bit and
>> >> 24-bit output I have to invert my transparency
>> >> values (i.e., change 25
>> >> to 75 and vice-versa) to get the same effect.
>>randy james wrote:
>>>I have been testing outputformat and switching
>>between
>>>PNG and PNG24 and never had to change anything.
>>Have
>>>you been using outputformat?
>>Yep, I'm using OUTPUTFORMAT for both. I can toggle
>>between the
>>imagetypes and see the transparency change on a
>>polygon layer when I
>>refresh the map.
>>#IMAGETYPE png8
>>IMAGETYPE png24
>>OUTPUTFORMAT
>> NAME png8
>> DRIVER "GD/PNG"
>> IMAGEMODE PC256
>> FORMATOPTION "INTERLACE=ON"
>>END
>>OUTPUTFORMAT
>> NAME png24
>> DRIVER "GD/PNG"
>> IMAGEMODE RGB
>>END
>>LAYER
>> NAME boundary
>> STATUS ON
>> TYPE POLYGON
>> DATA sevbnd83
>> TRANSPARENCY 35
>> CLASS
>> NAME "Boundary"
>> OUTLINECOLOR 110 110 110
>> COLOR 243 248 245
>> END
>>END
