[Mapserver-users] Transparency values - confusion
Frank Warmerdam
warmerdam at pobox.com
Fri Mar 14 10:51:28 EST 2003
Havard Tveite wrote:
> Frank Warmerdam wrote:
> > Dylan Keon wrote:
> >> I've noticed the same thing in 3.7. When I switch between 8-bit and
> >> 24-bit output I have to invert my transparency values (i.e., change 25
> >> to 75 and vice-versa) to get the same effect.
> > I will dig into this. I am pretty sure it is my fault.
> I think that the PNG24 way of doing things should be the
> preferred, so I hope that "PNG" (8 bit) behaviour and the
> documentation can be changed!
Well, the semantics are really up to Steve Lime. Steve, could you
clarify that TRANSPARENT is supposed to work like the mapfile reference
says, with TRANSPARENT=100 meaning opaque and TRANSPARENT=0 meaning
completely transparent? Any interest in reversing that?
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
