[Mapserver-users] mapscript/CGI by example
Daniel Morissette morissette at dmsolutions.ca
Fri Mar 14 11:24:22 EST 2003
Matt Doggett wrote:
> Warning: MapServer Error in msLoadMap():
> (/usr/local/apache2/htdocs/mdoggett/mapscript/europe.map) in
> /usr/local/apache2/htdocs/mapscript/example1.phtml on line 6
> Fatal error: Failed to open map file
> /usr/local/apache2/htdocs/mdoggett/mapscript/europe.map in
> I've checked all permissions, paths, files, etc and they are
> correct...what gives?
> The absolute path reference to europe.map is correct.  When I remove the
> absolute path reference and change it to relative (./europe.map) it
> works again!  So, why doesn't the absolute path work?  For a brief
> moment it did...then something changed.  Apache config?
If you can open the mapfile using "./europe.map", then I assume the
mapfile lives in the same directory as example1.phtml, correct?
If that's the case then absolute path should probably be
/usr/local/apache2/htdocs/mapscript/europe.map
Daniel
 DM Solutions Group              http://www.dmsolutions.ca/
