[Mapserver-users] PHP version and Maplab
Mat Brletic
mbrletic at visalia.k12.ca.us
Fri Mar 14 14:23:13 EST 2003
Paul Spencer wrote:
> Hi,
> the earliest version that MapLab was developed with was PHP 4.0.6.
> There have been a number of significant changes to PHP since 4.0.6.
> MapLab has undoubted taken advantage of at least some of those
> changes. Most significant is probably session handling and use of
> superglobals $GLOBALS, $_GET, $_POST, $_SESSION and some other
> changes. It is most likely that MapLab will not run on versions of
> PHP earlier than 4.2.x without at least some problems.
> Also note that there are many significant security and bug fixes that
> have happened after PHP 4.0.6 that should justify upgrading to a more
> recent version.
> Cheers,
> Paul
> Mat Brletic wrote:
>> Does anybody know if PHP 4.0.4 running on Apache 1.3.19 is sufficient
>> to properly run Maplab?
>> The "Maplab Installation Instructions for Linux" state that version
>> 4.2.x is supported (and required).
>> Mathew M. Brletic
>> IS Analyst
>> Visalia Unified School District
>> Visalia, CA 93277
>> Mapserver-users mailing list
>> Mapserver-users at lists.gis.umn.edu
>> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Thanks, Paul.
Mat
