[Mapserver-users] PHP version and Maplab
Lars Schylberg lars.schylberg at sssk.se
Fri Mar 14 16:18:09 EST 2003
Hi !
I have tried to set up and use Maplab this week under php 4.3.0. But
after some attemps and some
errors,  I read the documentation that told that Maplab is broken under
PHP 4.3.0.  I managed to get
it up ok with the demo data but the big map never showed.  Do anyone
know how far away
PHP 4.3.2 is ?  What is that is broken in MapLab and PHP 4.3.0 ?
/Lars Schylberg
Mat Brletic wrote:
> Paul Spencer wrote:
>> Hi,
>> the earliest version that MapLab was developed with was PHP 4.0.6.
>> There have been a number of significant changes to PHP since 4.0.6.
>> MapLab has undoubted taken advantage of at least some of those
>> changes.  Most significant is probably session handling and use of
>> superglobals $GLOBALS, $_GET, $_POST, $_SESSION and some other
>> changes.  It is most likely that MapLab will not run on versions of
>> PHP earlier than 4.2.x without at least some problems.
>> Also note that there are many significant security and bug fixes that
>> have happened after PHP 4.0.6 that should justify upgrading to a more
>> recent version.
>> Cheers,
>> Paul
>> Mat Brletic wrote:
>>> Does anybody know if PHP 4.0.4 running on Apache 1.3.19 is
>>> sufficient to properly run Maplab?
>>> The "Maplab Installation Instructions for Linux" state that version
>>> 4.2.x is supported (and required).
>>> Mathew M. Brletic
>>> IS Analyst
>>> Visalia Unified School District
>>> Visalia, CA 93277
>>> Mapserver-users mailing list
>>> Mapserver-users at lists.gis.umn.edu
>>> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> Thanks, Paul.
> Mat
