[Mapserver-users] PHP version and Maplab
Paul Spencer spencer at dmsolutions.ca
Fri Mar 14 16:26:17 EST 2003
Just a friendly reminder that this kind of traffic is more appropriate
to the maplab-users mailing list!
MapLab will work with PHP 4.3.0 and PHP 4.3.1 on Windows.  On Linux, PHP
mangles the value of PHP_SELF and this causes problems.  There have been
discussions on the mapserver mailing list about possible workarounds.
Cheers
Paul
Lars Schylberg wrote:
> Hi !
> I have tried to set up and use Maplab this week under php 4.3.0. But
> after some attemps and some
> errors,  I read the documentation that told that Maplab is broken under
> PHP 4.3.0.  I managed to get
> it up ok with the demo data but the big map never showed.  Do anyone
> know how far away
> PHP 4.3.2 is ?  What is that is broken in MapLab and PHP 4.3.0 ?
> /Lars Schylberg
> Mat Brletic wrote:
>> Paul Spencer wrote:
>>> Hi,
>>> the earliest version that MapLab was developed with was PHP 4.0.6.
>>> There have been a number of significant changes to PHP since 4.0.6.
>>> MapLab has undoubted taken advantage of at least some of those
>>> changes.  Most significant is probably session handling and use of
>>> superglobals $GLOBALS, $_GET, $_POST, $_SESSION and some other
>>> changes.  It is most likely that MapLab will not run on versions of
>>> PHP earlier than 4.2.x without at least some problems.
>>> Also note that there are many significant security and bug fixes that
>>> have happened after PHP 4.0.6 that should justify upgrading to a more
>>> recent version.
>>> Cheers,
>>> Paul
>>> Mat Brletic wrote:
>>>> Does anybody know if PHP 4.0.4 running on Apache 1.3.19 is
>>>> sufficient to properly run Maplab?
>>>> The "Maplab Installation Instructions for Linux" state that version
>>>> 4.2.x is supported (and required).
>>>> Mathew M. Brletic
>>>> IS Analyst
>>>> Visalia Unified School District
>>>> Visalia, CA 93277
>>>> _______________________________________________
>>>> Mapserver-users mailing list
>>>> Mapserver-users at lists.gis.umn.edu
>>>> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
>> Thanks, Paul.
>> Mat
Paul Spencer
Applications and Software Development
DM Solutions Group Inc.
http://www.dmsolutions.ca
