[Mapserver-users] Re: PHP version and Maplab
pkishor_98 pkishor at geoanalytics.com
Fri Mar 14 16:36:04 EST 2003
--- In mapserver-users at yahoogroups.com, Paul Spencer <pagameba at m...>
wrote:
> Just a friendly reminder that this kind of traffic is more appropriate
> to the maplab-users mailing list!
aha! if Lars had used the separate maplab list, I would have never
known about this. advantage case for a single, unified list.
however, since I am not using maplab at this point in time, this is
just bandwidth hogging trivia. advantage case for separate lists.
so, back to love-all.
How in heck did maplab manage its own list whilst other requests for
separate postgis list or separate lists for each flavor of mapscript
got assigned to devnull.
oh well.
> MapLab will work with PHP 4.3.0 and PHP 4.3.1 on Windows.  On Linux,
PHP
> mangles the value of PHP_SELF and this causes problems.  There have
been
> discussions on the mapserver mailing list about possible workarounds.
> Cheers
> Paul
> Lars Schylberg wrote:
> > Hi !
> > I have tried to set up and use Maplab this week under php 4.3.0. But
> > after some attemps and some
> > errors,  I read the documentation that told that Maplab is broken
under
> > PHP 4.3.0.  I managed to get
> > it up ok with the demo data but the big map never showed.  Do anyone
> > know how far away
> > PHP 4.3.2 is ?  What is that is broken in MapLab and PHP 4.3.0 ?
> > /Lars Schylberg
> > Mat Brletic wrote:
> >> Paul Spencer wrote:
> >>> Hi,
> >>> the earliest version that MapLab was developed with was PHP 4.0.6.
> >>> There have been a number of significant changes to PHP since 4.0.6.
> >>> MapLab has undoubted taken advantage of at least some of those
> >>> changes.  Most significant is probably session handling and use of
> >>> superglobals $GLOBALS, $_GET, $_POST, $_SESSION and some other
> >>> changes.  It is most likely that MapLab will not run on versions of
> >>> PHP earlier than 4.2.x without at least some problems.
> >>> Also note that there are many significant security and bug fixes
that
> >>> have happened after PHP 4.0.6 that should justify upgrading to a
more
> >>> recent version.
> >>> Cheers,
> >>> Paul
> >>> Mat Brletic wrote:
> >>>> Does anybody know if PHP 4.0.4 running on Apache 1.3.19 is
> >>>> sufficient to properly run Maplab?
> >>>> The "Maplab Installation Instructions for Linux" state that
version
> >>>> 4.2.x is supported (and required).
> >>>> Mathew M. Brletic
> >>>> IS Analyst
> >>>> Visalia Unified School District
> >>>> Visalia, CA 93277
> >>>> _______________________________________________
> >>>> Mapserver-users mailing list
> >>>> Mapserver-users at l...
> >>>> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> >> Thanks, Paul.
> >> Mat
> Paul Spencer
> Applications and Software Development
> DM Solutions Group Inc.
> http://www.dmsolutions.ca
