[Mapserver-users] GIS Student needs help
George McCown
reliant009 at charter.net
Fri Mar 14 22:16:37 EST 2003
I've removed the comment and corrected the the scr to:
<img border="1"src="/cgi-bin/mapserv.exe?map=/hall/single.map&mode=map">
I still cannot see the shp file. Can you guys help me again?
George
----- Original Message -----
To: <mapserver-users at lists.gis.umn.edu>
Sent: Friday, March 14, 2003 7:49 PM
Subject: Re: [Mapserver-users] GIS Student needs help
> George,
> Also you have to change src attribute to use your mapserver program with
your platform, e.g.
> <img .... src="/cgi-bin/mapserv.exe?map=.....">
> because in Windows, mapserver program is mapserv.exe. Demo setting is for
*n*x.
> Krung
> >George,
> >For starters, your LAYER line is commented out. Remove the leading #
> >from LAYER.
> >--Dylan
> >George McCown wrote:
> >> I've successfully installed the demo map server on apache 2.
> >> Now I want to learn how to make single layers but I need more help
> >> than what the Tutorial shows.
> >> data file: E:\Apache Group\Apache2\htdocs\hall\data\states.shp
> >> mapserv(3.6): E:\Apache Group\Apache2\cgi-bin
> >> single.map and single.html: E:\Apache Group\Apache2\htdocs\hall
> >> ********* Single.html**********************
> >> <html>
> >> <head>
> >> <title>single</title>
> >> </head>
> >> <body>
> >> <h1>SINGLE LAYER</h1>
> >> <img border="1"
src="="/cgi-bin/mapserv35?map/hall/single.map&mode=map">
> >> <p>why is it mapserv35?map not just mapserv.exe?</p>
> >> </body>
> >> </html>
> >> ************single.map*****************
> >> NAME test
> >> EXTENT -127.92 49.47 -77.05 23.66
> >> SIZE 400 300
> >> SHAPEPATH "data"
> >> #LAYER # start of the "states" layer object
> >> NAME "states"
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
