[Mapserver-users] GIS Student needs help
Dylan Keon
keon at nacse.org
Sat Mar 15 00:16:55 EST 2003
George,
Looks like your EXTENT isn't quite right. It should be "minx miny maxx
maxy" and you have "minx maxy maxx miny." So instead of "EXTENT -127.92
49.47 -77.05 23.66" try "EXTENT -127.92 23.66 -77.05 49.47"
Also, put the line "UNITS DD" somewhere in the map object, like right
after your EXTENT line (your shapefile *is* unprojected (lat/lon), right?).
You should also set up the WEB object. Fill in the IMAGEPATH and
IMAGEURL with the correct paths to the writeable temp directory. You
may also need to set up the HEADER and FOOTER in the WEB object,
depending on what you're trying to do.
See http://mapserver.gis.umn.edu/doc36/mapfile-reference.html for more
info on mapfile syntax.
So, try this (make sure to enter correct paths under the WEB object):
#************single.map*****************
NAME TEST
STATUS ON
UNITS DD
SIZE 400 300
SHAPEPATH "data"
WEB
IMAGEPATH "E:\Apache Group\Apache2\htdocs\temp\"
IMAGEURL "/temp/"
END
LAYER
NAME "states"
DATA states
STATUS DEFAULT
TYPE POLYGON
CLASS
COLOR 220 220 220
OUTLINECOLOR 0 0 0
END
END
END
--Dylan
George McCown wrote:
> I've removed the comment and corrected the the scr to:
> <img border="1"src="/cgi-bin/mapserv.exe?map=/hall/single.map&mode=map">
> I still cannot see the shp file. Can you guys help me again?
> George
> ----- Original Message -----
> From: "Krung Saengpole" <krung at cad.go.th>
> To: <mapserver-users at lists.gis.umn.edu>
> Sent: Friday, March 14, 2003 7:49 PM
> Subject: Re: [Mapserver-users] GIS Student needs help
>>George,
>>Also you have to change src attribute to use your mapserver program with
> your platform, e.g.
>><img .... src="/cgi-bin/mapserv.exe?map=.....">
>>because in Windows, mapserver program is mapserv.exe. Demo setting is for
> *n*x.
>>Krung
>>>George,
>>>For starters, your LAYER line is commented out. Remove the leading #
>>>from LAYER.
>>>--Dylan
>>>>I've successfully installed the demo map server on apache 2.
>>>>Now I want to learn how to make single layers but I need more help
>>>>than what the Tutorial shows.
>>>>data file: E:\Apache Group\Apache2\htdocs\hall\data\states.shp
>>>>mapserv(3.6): E:\Apache Group\Apache2\cgi-bin
>>>>single.map and single.html: E:\Apache Group\Apache2\htdocs\hall
>>>>********* Single.html**********************
>>>><html>
>>>><head>
>>>><title>single</title>
>>>></head>
>>>><body>
>>>><h1>SINGLE LAYER</h1>
>>>><img border="1"
> src="="/cgi-bin/mapserv35?map/hall/single.map&mode=map">
>>>><p>why is it mapserv35?map not just mapserv.exe?</p>
>>>></body>
>>>></html>
>>>>NAME test
>>>>EXTENT -127.92 49.47 -77.05 23.66
>>>>SIZE 400 300
>>>>SHAPEPATH "data"
>>>>#LAYER # start of the "states" layer object
>>>> NAME "states"
>>_______________________________________________
>>Mapserver-users mailing list
>>Mapserver-users at lists.gis.umn.edu
>>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
