[Mapserver-users] (Fwd) about tileindex shp
woodbri at swoodbridge.com woodbri at swoodbridge.com
Sat Mar 15 17:03:46 EST 2003
The relationship between tileindex location, the location string,
shapepath and data  and whether you specify absolute paths or
relative paths have been a very confusing to me in the past. I know a
bunch of work has been done to make them work in a more rational way
in 3.7.
In the past, I have just played with them til I was able to get
something to work. Maybe someone has a better explanation.
What version of Mapserver are you using?
------- Forwarded message follows -------
Date sent:      	Fri, 14 Mar 2003 13:27:59 +0800 (CST)
Subject:        	about tileindex shp
To:             	woodbri at swoodbridge.com
Hi!
i try to use tileindex shp according to
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?search=BathymetryHowTo
As a test, shp2img can generate the right gif
according to the simple map file. Then i use it on the
web, the tileindex layer doesn't work, but the other
vector/raster layers work fine. I check the setting to
confirm it almost the same as the map file i tested in
shp2img, except an additional TEMPLATE attribute.
Still not any reponse, just like the layer is not
there.
A question i wanna ask is how to check the warning or
error raised by mapserv.exe in cgi environment? if
mispell the shp name in map, "Unable to access file"
will shown while i use shp2img. But in cgi mode, i
can't see anything if a DATA attribute is deliberately
changed to wrong name. the layer will just not be
shown. (but when SHAPEPATH is wrong, the mapserv will
stop). I wonder whether mapserv complain something i
cant see.
Another question: it seems the layer dont use DATA
attribute. TILEINDEX take its place. But seems the
TILEINDEX can't accept the file with directory part
like "globe/dem.shp", only "dem.shp" is acceptable
(test in shp2img). Is it right? so we have to put the
tileindex shp in the SHAPEPATH directly? (I just do
like that, but don't know why mapserv is still mad at
me :< )
any idea and suggestion?
Remote Scensing Satellite Ground Station
Chinese Academy of Science
_________________________________________________________
Do You Yahoo!?
ÃÀÅ®ÃǵÄÃØÃÜÎäÆ÷£¡
http://yahoo.eachnet.com/fu/co/rd.php?http://pages.eachnet.com/st/page
/women/women.htm
------- End of forwarded message -------
