[Mapserver-users] 3.7 configure error with php 4.3.1
Paul Spencer
spencer at dmsolutions.ca
Thu Mar 13 09:33:56 EST 2003
Aaron, I had the same problem. It seems that php configure was changed
at some point and now you have to use --with-regex=system in the php
configure. Also, please note that there are some problems with php
4.3.0 and php 4.3.1 concerning the values reported by PHP_SELF that are
fixed in the latest snapshot. If you use PHP_SELF (and who doesn't ;))
I recommend using a snapshot.
Cheers,
Paul
Aaron D. Hunt wrote:
> When I run the config with
> ./configure --without-tiff --with-proj --with-gdal --with-ogr
> --with-jpeg --with-php=/usr/local/src/php-4.3.1
> I get:
> !!! The current version of PHP MapScript has some problems with !!!
> !!! PHP4's bundled regex. Until we figure the solution to the !!!
> !!! problem, the workaround is to compile PHP4 with the system regex !!!
> !!! Please re-configure and re-compile PHP4 with --with-system-regex !!!
> !!! and then re-configure and re-compile MapServer. !!!
> But, my php is configured with --with-system-regex (see attached).
> Is there any way around this?
> Aaron D. Hunt
