[Mapserver-users] filter with shp
John Hagstrand john.hagstrand at interageresearch.com
Tue Mar 18 21:41:51 EST 2003
Hi Steve,
Thanks for the reply.  I have a shapefile containing 500 polygons.  For any
given map request I want to pull out some two or three hundred polygons
depending on the value of a field.  So I tried doing this:
FILTER 'TIMEBEG < 1500 AND TIMEEND >= 1500'
That gets me an error.  Is there some way I can accomplish this objective?
Then of course there's another step: I want to vary the 1500 value
dynamically.  I wonder if there's a way to do that without rewriting the
whole mapfile each time.
How would you recommend I go about this?
Thanks
John
At 05:26 PM 3/18/2003, Steve Lime wrote:
>There's not much reason to use FILTER with shapefiles unless you're
>doing itemquery's. Filters exist primarily as a mechanism to invoke
>vendor specific SQL engines prior to MapServer getting access to
>features.
>Steve
> >>> John Hagstrand <john.hagstrand at interageresearch.com> 03/16/03
>09:15PM >>>
>Hi,
>Can you direct me to an example using a FILTER with a shapefile?
>Thanks
>John
>John Hagstrand
>Interage Research, Inc.
>847 838 5371
>Software Development Consulting for Internet Content Management
>We make knowledge accessible, useful, and relevant for everyone.
>http://www.interageresearch.com
>_______________________________________________
>Mapserver-users mailing list
>Mapserver-users at lists.gis.umn.edu
>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
John Hagstrand
847 838 5371
