[Mapserver-users] Transparency on Querymap hilite
Steve Lime
steve.lime at dnr.state.mn.us
Wed Mar 19 14:45:18 EST 2003
Query maps can be mimiced using regular old layers. Using your example
you could add a second class with an expression that you set only once a
query has been done. In regular modes the expression wouldn't match and
would be skipped. This works nicely when only a few features are
selected and it's easy to write an expression to isolate them. In your
case it might look like:
CLASS
# selected features are drawn with this
EXPRESSION "%myexpr%"
COLOR 255 0 0
OUTLINECOLOR 143 143 143
END
It goes before the other class and is only active when you pass
mapserver a variable called myexpr. Just a thought anyway. Otherwise the
request for transparency in a querymap should be filed in bugzilla...
Steve
>>> "Bernd Deckert" <bernd.deckert at wanadoo.fr> 03/14/03 06:49AM >>>
Dear Listmembers,
The final client of my cartographic intranet solution whishes
transparency on the queried geographic objects to "see behind the
objects".
Is there a way to apply a TRANSPARENCY on "HILITE" of QUERYMAP in
mapfile.
Probably not...
Is there an other way to obtain a sort of "transparency effect"
(without changing the layer properties) .
Thanks a lot
Bernd
QUERYMAP
COLOR 255 0 0
STYLE HILITE
END
The layers is something like this
LAYER
TRANSPARENCY 50
NAME "Rn"
GROUP "Nature"
METADATA
"LYRNAME" "Réserve naturelle nationale"
"CHAMPSSIG" "ID;Intitule_decret;SURFACE_SIG_km2"
"IDSIGIDBD" "ID"
END
STATUS ON
CONNECTIONTYPE OGR
CONNECTION "../../data/Rn_lr.TAB"
TOLERANCE 5
TYPE POLYGON
CLASS
NAME "Rn1"
COLOR 49 193 34
TEMPLATE "ttt_query.html"
END
END
