[Mapserver-users] Displaying Lat-Long grids in the map image?
Administrator
jnovak at novacell.com
Thu Mar 20 12:28:25 EST 2003
This is a multi-part message in MIME format.
------_=_NextPart_001_01C2EF06.1D34104E
Content-Type: text/plain;
charset="us-ascii"
Content-Transfer-Encoding: quoted-printable
Francisco,
=20
A GRID keyword has been added to LAYER in Mapserver 3.7 that provides
the functionality you're looking for. Here's an example:
=20
LAYER
NAME "GRID"
PROJECTION=20
"proj=3Dlatlong"
"ellps=3DWGS84"
"datum=3DWGS84"
END
TYPE LINE
STATUS DEFAULT
CLASS
COLOR 0 255 128
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 255 128 89
END
END
GRID
MININTERVAL 0.10
MAXINTERVAL 0.10
# INTERVALCOUNT 10
# MINARCS 16
# MAXARCS 16
LABELFORMAT "DDMMSS"=20
END
END
=20
This will render a grid in Lat-Long with one tenth degree spacing and
degree minute second labels. For variable spacing, remove the min, max
interval tags.
=20
To allow Mapserver to pick defaults for the grid, simply specify
=20
GRID
END
=20
in your layer.
=20
Regards,
=20
John Novak
Novacell Technologies
www.novacell.com
-----Original Message-----
From: Francisco Delgado [mailto:fdelgado at snet.gob.sv]=20
Sent: Thursday, March 20, 2003 7:20 AM
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] Displaying Lat-Long grids in the map image?
Hello everybody.
=20
I want to set up my maps to show the Lat-Long (UTM or whatever) grids. I
got the idea that there is no way to add them as a property of the map
file, am I right? In that case, does someone has a clever idea to do
this? I made a shapefile with the gridlines cathegorized to show
different densities of gridlines at different scale levels, but I guess
that there must be much more elegant alternatives.
=20
Thank you all.
=20
Francisco Delgado
Informatica - SNET
http://www.snet.gob.sv
Content-Type: text/html;
charset="us-ascii"
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Dus-ascii">
<TITLE>Message</TITLE>
<META content=3D"MSHTML 5.50.4522.1800" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#ffffff>
<DIV><SPAN class=3D782271717-20032003><FONT face=3DArial color=3D#0000ff =
size=3D2>Francisco,</FONT></SPAN></DIV>
size=3D2></FONT></SPAN> </DIV>
size=3D2>A GRID=20
keyword has been added to LAYER in Mapserver 3.7 that provides the =
functionality=20
you're looking for. Here's an example:</FONT></SPAN></DIV>
size=3D2>LAYER<BR> NAME "GRID"<BR> =
PROJECTION <BR> =20
"proj=3Dlatlong"<BR> "ellps=3DWGS84"<BR> =20
"datum=3DWGS84"<BR> END<BR> TYPE LINE<BR> STATUS=20
DEFAULT<BR> CLASS<BR> COLOR 0 255 128<BR> =20
LABEL<BR> TYPE BITMAP<BR> SIZE =
MEDIUM<BR> COLOR=20
255 128 89<BR> END<BR> END<BR> =
GRID<BR> MININTERVAL=20
0.10<BR> MAXINTERVAL 0.10<BR># INTERVALCOUNT=20
10<BR># MINARCS =
16<BR># MAXARCS =20
16<BR> LABELFORMAT "DDMMSS" <BR> =
END<BR>END</FONT></SPAN></DIV>
size=3D2>This=20
will render a grid in Lat-Long with one tenth degree spacing and degree =
minute=20
second labels. For variable spacing, remove the min, max interval=20
tags.</FONT></SPAN></DIV>
size=3D2>To=20
allow Mapserver to pick defaults for the grid, simply=20
specify</FONT></SPAN></DIV>
size=3D2>GRID</FONT></SPAN></DIV>
size=3D2>END</FONT></SPAN></DIV>
size=3D2>in=20
your layer.</FONT></SPAN></DIV>
size=3D2>Regards,</FONT></SPAN></DIV>
size=3D2>John=20
Novak</FONT></SPAN></DIV>
size=3D2>Novacell Technologies</FONT></SPAN></DIV>
size=3D2><A=20
href=3D"http://www.novacell.com">www.novacell.com</A></FONT></SPAN></DIV>=
<BLOCKQUOTE dir=3Dltr style=3D"MARGIN-RIGHT: 0px">
<DIV></DIV>
<DIV class=3DOutlookMessageHeader lang=3Den-us dir=3Dltr =
align=3Dleft><FONT=20
face=3DTahoma size=3D2>-----Original Message-----<BR><B>From:</B> =
Francisco=20
Delgado [mailto:fdelgado at snet.gob.sv] <BR><B>Sent:</B> Thursday, March =
20,=20
2003 7:20 AM<BR><B>To:</B>=20
mapserver-users at lists.gis.umn.edu<BR><B>Subject:</B> [Mapserver-users] =
Displaying Lat-Long grids in the map image?<BR><BR></FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Hello everybody.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>I want to set up my maps to show the =
Lat-Long=20
(UTM or whatever) grids. I got the idea that there is no way to add =
them as a=20
property of the map file, am I right? In that case, does someone has a =
clever=20
idea to do this? I made a shapefile with the gridlines cathegorized to =
show=20
different densities of gridlines at different scale levels, but I =
guess that=20
there must be much more elegant alternatives.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Thank you all.</FONT></DIV>
<DIV><FONT face=3DArial =
size=3D2>---------------------------------<BR>Francisco=20
Delgado<BR>Informatica - SNET<BR><A=20
href=3D"http://www.snet.gob.sv">http://www.snet.gob.sv</A></FONT></DIV></=
BLOCKQUOTE></BODY></HTML>
------_=_NextPart_001_01C2EF06.1D34104E--
