[Mapserver-users] Displaying Lat-Long grids in the map image?
Jan Hartmann jhart at frw.uva.nl
Mon Mar 24 07:22:43 EST 2003
John,
Am I right that labels have to be provided? When I try to draw the grid
layer without a LABEL, MapServer crashes. With labels it runs OK,
although it takes plenty of time, much more than when displaying a grid
based on a shapefile layer.
Jan
Administrator wrote:
> Francisco,
> A GRID keyword has been added to LAYER in Mapserver 3.7 that provides
> the functionality you're looking for.  Here's an example:
> LAYER
>   NAME "GRID"
>   PROJECTION
>    "proj=latlong"
>    "ellps=WGS84"
>    "datum=WGS84"
>   END
>   TYPE LINE
>   STATUS DEFAULT
>   CLASS
>  COLOR 0 255 128
>    LABEL
>   TYPE BITMAP
>   SIZE MEDIUM
>   COLOR 255 128 89
>    END
>   END
>   GRID
>  MININTERVAL 0.10
>  MAXINTERVAL 0.10
> # INTERVALCOUNT 10
> # MINARCS   16
> # MAXARCS     16
>   LABELFORMAT "DDMMSS"
>   END
> END
> This will render a grid in Lat-Long with one tenth degree spacing and
> degree minute second labels.  For variable spacing, remove the min, max
> interval tags.
> To allow Mapserver to pick defaults for the grid, simply specify
> GRID
> END
> in your layer.
> Regards,
> John Novak
> Novacell Technologies
> www.novacell.com <http://www.novacell.com>
>     -----Original Message-----
>     *From:* Francisco Delgado [mailto:fdelgado at snet.gob.sv]
>     *Sent:* Thursday, March 20, 2003 7:20 AM
>     *To:* mapserver-users at lists.gis.umn.edu
>     *Subject:* [Mapserver-users] Displaying Lat-Long grids in the map image?
>     Hello everybody.
>     I want to set up my maps to show the Lat-Long (UTM or whatever)
>     grids. I got the idea that there is no way to add them as a property
>     of the map file, am I right? In that case, does someone has a clever
>     idea to do this? I made a shapefile with the gridlines cathegorized
>     to show different densities of gridlines at different scale levels,
>     but I guess that there must be much more elegant alternatives.
>     Thank you all.
>     Francisco Delgado
>     Informatica - SNET
>     http://www.snet.gob.sv
