[Mapserver-users] Re: filter with shp
Eduardo Spremolla
edspremolla at Antel.com.uy
Fri Mar 21 07:58:50 EST 2003
I'm trying to use dynamic expressions from CGI, but in:
<input type="hidden" id="clase" name="map_moviles_class_2_expression"
value="[map_moviles_class_2_expression]">
the value did not get substituted.
What I wont is to later modify the value with javascript prior to post.
By the way [map_moviles_data] works ok and I have 3 classes in moviles.
Thanks in advance
LALO
On Thu, 2003-03-20 at 22:43, John Hagstrand wrote:
> Hi Jan,
> Thank you very much. I've got it working now. Excellent. (I see I should
> have been able to figure it out from the documentation.)
> Thanks
> John
> John,
> As Steve says, you don't need FILTER to select from shapfiles. Just
> define a CLASS like:
> CLASS
> EXPRESSION "([TIMEBEG] < 1500 AND [TIMEEND] >= 1500)"
> END
> Take care of the syntax! Quoting from the MapFile reference (under CLASS
> / EXPRESSION):
> > Logical expressions allow you to build fairly complex tests based on
> > one or more attributes and therefore are only available with
> > shapefiles. Logical expressions are delimited by parentheses
> > "(expression)". Attribute names are delimited by square brackets
> > "[ATTRIBUTE]". These names are case sensitive and must match the items
> > in the shapefile. For example: EXPRESSION ([POPULATION] > 50000 AND
> > '[LANGUAGE]' eq 'FRENCH') ... The following logical operators are
> > supported : =,>,<,<=,>=,=,or,and,lt,gt,ge,le,eq. As you might expect
> > this level of complexity is slower to process.
> On your second question: you can specify an expression dynamically in
> the calling URL:
> http://.../mapserv?map=my.map&layer=...&map_layer_0_class_0.expression="{...)"
> See the end of the MapFile reference for this very powerful mechanism.
> BTW I'm not sure if the FILTER statement works as specified in the CVS
> version of MapServer. I tried the following on a world-map:
> FILTERITEM name
> FILTER France
> and got a map of France. However
> FILTER "name='France'"
> gave back the whole world. I tried various permutations of quotes,
> brackets and capitals, but always got back the whole world. Am I missing
> something?
> Jan
> > Hi Steve,
> > Thanks for the reply. I have a shapefile containing 500 polygons. For
> > any given map request I want to pull out some two or three hundred
> > polygons depending on the value of a field. So I tried doing this:
> > FILTER 'TIMEBEG < 1500 AND TIMEEND >= 1500'
> > That gets me an error. Is there some way I can accomplish this objective?
> > Then of course there's another step: I want to vary the 1500 value
> > dynamically. I wonder if there's a way to do that without rewriting the
> > whole mapfile each time.
> > How would you recommend I go about this?
> > Thanks
> > John
> > At 05:26 PM 3/18/2003, Steve Lime wrote:
> >> There's not much reason to use FILTER with shapefiles unless you're
> >> doing itemquery's. Filters exist primarily as a mechanism to invoke
> >> vendor specific SQL engines prior to MapServer getting access to
> >> features.
> >> Steve
> >> >>> John Hagstrand <john.hagstrand at interageresearch.com> 03/16/03
> >> 09:15PM >>>
> >> Hi,
> >> Can you direct me to an example using a FILTER with a shapefile?
> >> Thanks
> >> John
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
