[Mapserver-users] 3.7_23mar breaking where 3.6.3 ran fine ??
Thorsten Fischer thfischer at mapmedia.de
Mon Mar 24 04:34:22 EST 2003
On Sun, 2003-03-23 at 19:28, Dylan Keon wrote:
> After just a cursory glance I noticed you have OFFSITE defined on at
> least one layer.  The syntax for OFFSITE has changed (now requires RGB
> value instead of color index value), and I know for a fact that will
> cause your app to fail with no warning.
I know for a fact that it won't :) It does fail though of course, but it
will complain in a different way; in the first layer 'relief' for
example, it will try to interpret the next three tokens after 'OFFSITE'
as numbers. This will fail because 'END' obviously isn't a number. The
error I have seen so far in this case is a 'getInteger' error.
But maybe this has changed ... I stumbled over this some time ago, and
it may have changed. ymmv.
hth,
thorsten
