[Mapserver-users] 3.7_23mar breaking where 3.6.3 ran fine ??
Gerry Creager N5JXS gerry.creager at tamu.edu
Mon Mar 24 08:11:08 EST 2003
Nope.  getInteger is still the failure mode...
gerry
Thorsten Fischer wrote:
> On Sun, 2003-03-23 at 19:28, Dylan Keon wrote:
>>After just a cursory glance I noticed you have OFFSITE defined on at
>>least one layer.  The syntax for OFFSITE has changed (now requires RGB
>>value instead of color index value), and I know for a fact that will
>>cause your app to fail with no warning.
> I know for a fact that it won't :) It does fail though of course, but it
> will complain in a different way; in the first layer 'relief' for
> example, it will try to interpret the next three tokens after 'OFFSITE'
> as numbers. This will fail because 'END' obviously isn't a number. The
> error I have seen so far in this case is a 'getInteger' error.
> But maybe this has changed ... I stumbled over this some time ago, and
> it may have changed. ymmv.
> hth,
> thorsten
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Gerry Creager -- gerry.creager at tamu.edu
Network Engineering -- AATLT, Texas A&M University
Cell: 979.229.5301 Office: 979.458.4020 FAX: 979.847.8578
Page: 979.228.0173
Office: 903A Eller Bldg, TAMU, College Station, TX 77843
