[Mapserver-users] 3.7_23mar breaking where 3.6.3 ran fine ??
Dylan Keon keon at nacse.org
Mon Mar 24 10:20:40 EST 2003
Thorsten Fischer wrote:
> On Sun, 2003-03-23 at 19:28, Dylan Keon wrote:
>>After just a cursory glance I noticed you have OFFSITE defined on at
>>least one layer.  The syntax for OFFSITE has changed (now requires RGB
>>value instead of color index value), and I know for a fact that will
>>cause your app to fail with no warning.
> I know for a fact that it won't :) It does fail though of course, but it
> will complain in a different way; in the first layer 'relief' for
> example, it will try to interpret the next three tokens after 'OFFSITE'
> as numbers. This will fail because 'END' obviously isn't a number. The
> error I have seen so far in this case is a 'getInteger' error.
You are correct...it results in a getInteger() error in the error_log,
because of the reasons you mentioned.  What I meant was that it suddenly
results in a blank screen.  I didn't explain that well.
Thanks,
Dylan
