[Mapserver-users] ArcExplorer 4.0.1 and Mapserver WMS - Wiki page
Thomas Bartlett tbartlett at dddd.com.au
Mon Mar 24 23:12:42 EST 2003
Thanks for the speedy reply Antti,
Can you clarify "point 3" !
I have only added:
<?php header("Content-type:application/vnd.ogc.gml");   ?>
at the top of the XML document, am I missing something ??
I have noted that when I load wms.php into a web-browser I get an error
displayed (not a PHP but a HTTP error [like HTTP 404 - File not found]) and
when I view the source on that error document I see the XML document, but
php has not adding anything eg a header??  Should there be something there
Thanks again !!
Tom
----- Original Message -----
To: <tbartlett at dddd.com.au>; <mapserver-users at lists.gis.umn.edu>
Sent: Tuesday, March 25, 2003 2:56 PM
Subject: RE: [Mapserver-users] ArcExplorer 4.0.1 and Mapserver WMS - Wiki
page
> Hi Thomas,
> To answer your questions:
> 1. The client is Windows 2000 Pro. The server is Mapserver 3.6.1
> or 3.6.4 on Linux depending on whether it's my dev box or not.
> 2. My guess is that it means that it is probably OK. I'd try and
> test it by issuing getMap requests manually or pointing one of the
> online WMS clients (such as Cubewerx) at it. I am not sure about how
> detailed the checking inside Mapserver is, though it is acceptable
> to Arc Explorer.
> 3. Shouldn't be anything special. Just remember that you can't send
> headers as part of a web request after any regular output (STDOUT)
> has been sent. PHP will generate an error and tell you if you try. :o)
> FWIW, I found getting the syntax just right to be the most fiddley
> part of the operation.
> Cheers,
> Antti
> -----Original Message-----
> From: Thomas Bartlett [mailto:tbartlett at dddd.com.au]
> Sent: Tuesday, 25 March 2003 2:30 PM
> To: Antti.Roppola at brs.gov.au; mapserver-users at lists.gis.umn.edu
> Subject: Re: [Mapserver-users] ArcExplorer 4.0.1 and Mapserver WMS -
> Wiki page
> G'Day Antti,
> Thanks for posting the document on wiki !!
> I'm trying to get ArcExplorer connecting to MapServer... without a lot of
> success to date.
> I have a couple of questions:
> 1.  What type of system did you manage to get it working on, and will it
> work in a window environment.  I am using the MapServer 3.6.3 windows
binary
> from the mapserver website (which says it is OGC WMS compliant.  as does
> running mapserv -v
> 2.  If the "GetCapatiblies" XML document contains no "WARNINGS" does this
> mean it is WMS compliant?  Or just no obvious issues which will cause
> ArcExplorer to fail !
> 3.  I am currently using a windows binary version of PHP (CGI only) are
they
> any issue there ? eg. getting the header part of the document inserted ??
> I have gone through the WMSMapServer document, but I can't find any
obvious
> non-WMS compliant parts.
> Any ideas
> Many thanks
> Tom Bartlett
> From: <Antti.Roppola at brs.gov.au>
> To: <mapserver-users at lists.gis.umn.edu>
> Cc: <akrherz at iastate.edu>
> Sent: Friday, March 21, 2003 2:38 PM
> Subject: [Mapserver-users] ArcExplorer 4.0.1 and Mapserver WMS - Wiki page
> > Hello all,
> > Since I got ArcExplorer talking to Mapserver using the advice Daryl
> Herzmann recently
> > posted to the group (plus some direct assistance from him), I have put a
> set of notes
> > up on the Wiki:
> > http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?WMSMapserverArcExplorer
> > This is also accessible through the WMSMapServer link on the main page.
> > Cheers,
> > Antti
> > Mapserver-users mailing list
> > Mapserver-users at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
