[Mapserver-users] reproject raster datat
Heiko.Kehlenbrink at vermes.fh-oldenburg.de Heiko.Kehlenbrink at vermes.fh-oldenburg.de
Tue Mar 25 11:20:17 EST 2003
Quoting Frank Warmerdam <warmerdam at pobox.com>:
> Heiko.Kehlenbrink at vermes.fh-oldenburg.de wrote:
> > hi all,
> > got a little prolem reprojecting raster data with the mapserver.
> > in the web section i`ve set proj=latlong
> > and in the layer definition
> > init=epsg:4326.
> > i recive such an error message:
> > Warning: MapServer Error in msDrawRasterLayer( TIFF ): Raster
> reprojection
> > supported only
> > with the GDAL library. in /srv/www/htdocs/world/htdocs/test.phtml on
> line 78
> > though the php-info page says :
> > MapScript
> > MapScript Version ($Revision: 1.104.2.5 $ $Date: 2002/10/28 21:47:53
> > MapServer version 3.6.4 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> > SUPPORTS=PROJ SUPPORTS=TTF SUPPORTS=WMS_SERVER
> > SUPPORTS=WMS_CLIENT INPUT=TIFF INPUT=EPPL7 INPUT=JPEG
INPUT=POSTGIS
> > INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> > any hinds for me?
> Heiko,
> You need to force the GDAL TIFF support to be used in preference to
> the
> built-in libtiff support in MapServer.  I would suggest reconfiguring,
> and
> building with the --without-libtiff configure switch.  This will ensure
> that
> TIFF files are handled through GDAL which supports reprojection.
> Good luck,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for
> Rent
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Thanks Frank,
that does the trick...
But i also had to disable -without--tiff
Best Regards
Heiko
