[Mapserver-users] PHP Mapscript Problem
chodgson at refractions.net
Tue Mar 25 20:12:48 EST 2003
This message is in MIME format.
--=_41b84a744625f462190f001a
Content-Type: text/plain
Content-Disposition: inline
Content-Transfer-Encoding: 7bit
My problem is this:
The attached mapfile displays correctly for me using basic mapserver in map
mode (straight image output). If I do something along the lines of:
dl('php_mapscript.so');
$map = ms_newMapObj( '/home/chodgson/www/vsa/vsa.map' );
$map->setExtent( $minx, $miny, $maxx, $maxy );
$image = $map->draw();
header( "Content-Type: image/png" );
$image->saveImage( '', MS_PNG, 0, 0, 0 );
in PHP mapscript, I am unable to display the "lhas" layer. The reason I want to
use mapscript is to dynamically generate the classes for the lhas layer. At
first, I thought it was my class manipulation in PHP that was causing this
layer not to display, but after moving all of the class definitions into the
mapfile, I am still unable to display them using mapscript - even though it
displays fine using mapserver alone. Yes, I have tried using mapscript to set
the status of the lhas layer to MS_ON, to no effect.
What's up with this? Has anyone else experienced a similar problem before?
Thanks,
Chris
Content-Type: text/plain;
name="vsa.map"
Content-Disposition: attachment;
filename="vsa.map"
Content-Transfer-Encoding: base64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--=_41b84a744625f462190f001a--
