[Mapserver-users] Re: Mac OS X Apache Install Question
pkishor_98 pkishor at geoanalytics.com
Thu Mar 27 12:04:42 EST 2003
Hi Justin,
Sorry for the delay in responding to you. Type ./configure --help and
see the message... there is a lot of detail there. I don't recall off
the top of my head but it is something like
./configure --with-gd[=static,]DIR]
etc.
However, I recall from an earlier post of yours... you were having
some trouble running ms on your host's machine (is that right?). You
were getting some apache error logs, weren't you?
It well might be that your ms binary is compiled fine... but there
might be some other error, such as permissions (the commonest bugaboo).
I while back I compiled ms on my iBook, and then copied the binary to
my daughter's iMac, and it worked just fine. The iMac doesn't even
have developer's tools on... nothing.
My feeling is that your ms will work on another MacOS X box without
any hassles. If anything, it will be permissions or httpd.conf
problems that will cause you heartburn.
Hth.
--- In mapserver-users at yahoogroups.com, soprina <soprina at m...> wrote:
> Thanks for all the info.  I am quite new to unix and compiling on mac
> os x and appreciate all your help.
> So my next question would be how would I go about statically linking
> all the libraries when compiling mapserver.  I know there are good
> reasons for not doing this but I am just thinking about portability and
> the problem I am currently facing. I definitely need to be able to
> transfer the binary from one machine to another without having  to
> install a range of supporting libraries.  I currently do this with a
> windows compile of mapserver and it works well.  Alternatively is it
> possible that any libraries needed are created/moved to the same folder
> that mapserver is compiled in and if so is it likely that mapserver
> will work when the all the files are then transfer to another machine?
> My current configure command for compile is as follows if this is of
> any help?
> ./configure --with-gd --without-tiff --with-jpeg
> --with-proj=/mapserver/libraries/proj-4.4.5
> --with-gdal=/sw/bin/gdal-config
> --with-ogr=/mapserver/libraries/gdal-1.1.8/ogr
> Thanks again for your help
> Justin
> Mapserver-users mailing list
> Mapserver-users at l...
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
