[Mapserver-users] PHP Mapscript Problem
chodgson at refractions.net chodgson at refractions.net
Wed Mar 26 14:36:07 EST 2003
OK, so, my solution is this:
After beating my head against a wall for most of the day, it became obvious
that my php_mapscript.so wasn't compiled against the same version of mapserver
as my mapserv executable... so, I down'd v3.6.5 of mapserver, compiled myself a
new php mapscript, and voila, it works!
Thought I'd post this answer to my problem, as obvious as it may be...
Chris
Quoting chodgson at refractions.net:
> My problem is this:
> The attached mapfile displays correctly for me using basic mapserver in map
> mode (straight image output). If I do something along the lines of:
> dl('php_mapscript.so');
> $map = ms_newMapObj( '/home/chodgson/www/vsa/vsa.map' );
> $map->setExtent( $minx, $miny, $maxx, $maxy );
> $image = $map->draw();
> header( "Content-Type: image/png" );
> $image->saveImage( '', MS_PNG, 0, 0, 0 );
> in PHP mapscript, I am unable to display the "lhas" layer. The reason I want
> to
> use mapscript is to dynamically generate the classes for the lhas layer. At
> first, I thought it was my class manipulation in PHP that was causing this
> layer not to display, but after moving all of the class definitions into the
> mapfile, I am still unable to display them using mapscript - even though it
> displays fine using mapserver alone. Yes, I have tried using mapscript to set
> the status of the lhas layer to MS_ON, to no effect.
> What's up with this? Has anyone else experienced a similar problem before?
> Thanks,
> Chris
----- End forwarded message -----
