[Mapserver-users] Using several bitmap map files
Lowell Filak lfilak at medinaco.org
Thu Mar 27 09:23:52 EST 2003
Mapserver can use a shapefile as a tile index to make several adjacent images appear as a single image.
There is a PerlMapscript utility in the wiki to actually create the tileindex shapefile from a directory containing a group of tiff's & tfw's at:
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?PerlMapScriptExamples35ex1
HTH
Lowell F.
The following message was sent by =?iso-8859-1?Q?"Bernhard=20Rosenkr=E4nzer"?= <bero.rh at web.de> on Thu, 27 Mar 2003 15:03:35 +0100.
> Hi,
> Is there any way to set up mapserver (I'm using 3.6.5) to handle different (adjacent) geotiff map images as one
> map? (Simply combining the various files into one huge bitmap would probably do the job, but I'm scared of
> the performance/memory impact of using a 20 GB bitmap file)
> I know using bitmaps for this sort of thing is probably not a good idea - unfortunately it's the only format in
> which we can get the data.
> Any ideas?
> Thanks,
> Bernhard
> ______________________________________________________________________________
> Schon wieder Viren-Alarm? Bei WEB.DE FreeMail ist das kein Problem,
> hier ist der Virencheck inklusive! http://freemail.web.de/features/?mc=021158
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
