[Mapserver-users] PERL Mapscript under Cygwin
Lowell Filak lfilak at medinaco.org
Thu Mar 27 09:10:50 EST 2003
Great work.
I'm sure it will help many.
Do you have plans to add this to the wiki or is that something you would like someone else to do?
Lowell F.
The following message was sent by Joe Bussell <joe at otsys.com> on Wed, 26 Mar 2003 14:18:29 -0800.
> Greetings Listers,
>     Marketing came in the other day insisting on a TrafficDodger that
> works complete under Windows.  One of the major hurdles for us is our
> use of PERL Mapscript for handling dynamic data (routes, incidents &
> speeds).  One solution was to build Mapscript under Cygwin.  I went to
> the Wiki, downloaded the latest and greatest, then attempted a build.  I
> ran into a number of snags which I was able to hack my way around.  I
> have now produced a useful PERL Mapscript build under Cygwin. Now that
> Marketing doesn't care as much any more I thought I would pass on what I
> learned before it is meaningless.
>     The wiki is correct on many points, but there are some gotchas along
> the way.  First thing, one that seldom is mentioned directly, is that
> there is an order to what gets made first.  GD needs freetype for one
> thing.  This is what I did:
> 1) Build a Cygwin environment with:
>     build tools (make, cmake, libtool, gcc, flex, bison, ... )
>     perl
>     Make sure that you DO NOT have Cygwin's Postgresql installed, this
> makes the compile of gdal fail.  On multiple machines objdump reported
> that pq.dll was an unrecognized format (any ideas on why?)
>     I didn't bother with the Cygwin native gd or freetype either.
> 2) Download appropriate sources:
> 	freetype-2.1.3
> 	gd-2.0.11
> 	gdal-1.1.8
> 	proj-4.4.6
> 	mapserver-3.6.5
> 3) Build freetype.
>     This is trivial, you will need to run:
>     ./configure
>     make
>     make install
> 4) Build gd
>     ./configure
>     make
>     make install
> 5) build gdal
>     This is where things get weird and more work needs to be done.  You
> will need to run:
>     ./configure
>     make
>     make install
>     edit the installed gdal-config.  This is necesary as the install
> part of the makefile makes the choice that the library is not shared.
> The libraries that gdal-config reports are incorrectly articulated in
> the LIBS string.  Specifically the '-l' is prepended to all libraries
> independent of their shared-ness.  If the path ends with a '.a' it
> should not be prepended with -l.  Additionally, the installer requires
> the addition of -l/usr/local/lib/lib which is just clearly wrong.  Your
> mileage may vary.  One build actually went completely correct with no
> edit required.
> 6) Build proj
>     ./configure
>     make
>     make install
> 7) Build Mapserver
>      Edit the Makefile.in so the following are correct:
> HEADER_INSTALL=/usr/local/include/mapserver-3.6/
> LD=     g++
> then I used
>     ./configure   --with-gd --with-proj=/usr/local --with-freetype \
> --with-gdal=/usr/local/bin/gdal-config
> followed by:
>     make
>     make install
> 8) Now for the PERL Mapscript part.  This is also weird and will require
> upstream patches to really be correct.  To reproduce my hand hack first
> you need to run:
> perl Makefile.PL
> the Makefile you just creaed is not perfect.  Edit it such that the
> linker is g++ as in step 7.
> The link will still fail since gdal was built as a non-shared library.
> The linker will need the extra libs to make the dllwrap call work.  To
> accomplish this I added the back-ticked command
> `/usr/local/bin/gdal-config --libs` to the end of the list of LDLOADLIBS.
> Why the list isn't properly propagated from LIBS, which is correct in
> the Makefile, is unknown to me at this point.  It really should be fixed
> in MakeMaker.
> There is still one extra hook.  dllwrap makes use of ld2, which is just
> a thin wrapper around perlld in Cygwin.  The perlld in /usr/local/bin/
> in my Cygwin envoronment tries to use ld as its linker.  This fails to
> bring in the OGR and GDAL bits.  You will need to edit
> /usr/local/bin/perlld.exe to have
> driver_name = g++;
> now you can run
>      make
>      make install
> You will still have to be sure to fully qualify mapscript objects when
> calling 'new' on them.  dump.pl in the examples does not do this
> correctly (see previous posts).
> My hope is that the folks working on gdal can work out the shared
> library bits to improve the installed gdal-config.  I also would like to
> see the Makefiles be built using g++ as the linker when it is available.
>   I am unsure what my change to perlld will do to other perl builds (ie
> CPAN).  I have install from CPAN after the change and did not observe
> any new problems.
> I hope that this is useful to someone as I fear it was an exercise in
> futility for me.  I am very happy with the uptime of our *nix servers
> and am not inclined to push for Windows solutions in the near future.
> It could haunt me later however, so I am sending these bits to you folks
> hoping for improvements.
> Cordially,
> Joe Bussell
> On Time Systems
> www.trafficdodger.com
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
