[Mapserver-users] Date comparison
Jan Hartmann
jhart at frw.uva.nl
Thu Mar 27 13:21:02 EST 2003
Brigitte,
In PostgreSQL you can cast variables into another type with the ::
operator or cast() function.
http://www.postgresql.org/docs/view.php?version=7.3&idoc=0&file=sql-expressions.html#SQL-SYNTAX-TYPE-CASTS
Alternatively, you can use specialized functions for dates like to_char():
http://www.postgresql.org/docs/view.php?version=7.3&idoc=0&file=functions-formatting.html
If you put something like that in the SQL-string, the date value will be
converted to a text string, and MapServer can read it. I don't have
examples at hand, so you will have to experiment a bit with psql to see
how it works.
Jan
Luz Brigitte wrote:
> I have a problem when I´m trying to write a logical expression to filter
> a postgres table based on a Date type field, for example : 28/02/2003.
> I don´t sure, but I think that Mapserver don´t read date expression.
> A part of my code in Mapserver is:
> LAYER
> NAME "Clientes"
> STATUS DEFAULT
> DATA "the_geom from (select the_geom, geoclientes.oid,
> geoclientes.id, cliente.id_cliente, cliente.nit, contratos.vigencia,
> contratos.fecha_final, contratos.fecha_inicial from geoclientes inner
> join cliente on (geoclientes.id = cliente.id_cliente) inner join
> contratos on (geoclientes.id = contratos.id_cliente)) as query"
> TYPE POINT
> CONNECTIONTYPE POSTGIS
> CONNECTION "user=postgres dbname=namedb host=domain port=5432"
> # CLASSITEM "fecha_final"
> LABELITEM "ID"
> LABELMAXSCALE 10000
> CLASS
> NAME "contratos vigencia de 0 2 meses"
> # IN THE NEXT LINE I NEED TO DO COMPARISON WITH ACTUAL DATE -
> fecha_final field.
> EXPRESSION ('[fecha_inicial]' eq '01-02-2002')
> # EXPRESSION ([fecha_final] - [fecha_inicial] > "365")
> SYMBOL 7
> COLOR 255 255 0
> OUTLINECOLOR 153 153 0
> SIZE 8
> LABEL
> TYPE TRUETYPE
> FONT "Arialbold"
> SIZE 8
> POSITION AUTO
> COLOR 0 0 0
> OUTLINECOLOR 255 255 255
> PARTIALS FALSE
> END
> END
> END
> How do I perform a value-like comparison with dates in Mapserver to make
> queries.
> Thanks a lot for your help.
> Brigitte P.
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Jan Hartmann
Department of Geography
University of Amsterdam
jhart at frw.uva.nl
