[Mapserver-users] (no subject)
mapserv at dinequest.us
Fri Mar 28 00:20:43 EST 2003
Quoting mapserv at dinequest.us:
oops! i forgot to mention just in case, here is the url that i send to mapserv:
http://www.dinequest.us/cgi-bin/mapserv?map=/usr/local/psa/home/vhosts/dinequest.us/cgi-bin/demo.map&request=getmap&version=1.1.0&bbox=-67,45,-66,44
the local host is exactly the same, except for the map dir. and it works.
Thanks again for your time. -brandon
> thanks for responding, Steve,
> - I've tried what you've said with the trailing slash (in the mapfile)- i
> still
> recieved a "premature end of script headers" error.
> - I've moved the data folder into my httpdocs folder and adjusted my map file
> to
> point there instead- same result.
> - reset permissions on my cgi-bin, shp files, map file and shp file "data"
> dir
> to chmod 7777- same result.
> - I re-uploaded mapserv (static library file 2.5 megs) in ASCII mode, just
> to
> make sure i actually did send it ascii and not binary- same result.
> - I installed apache on my redhat 2.4.18-3 box and set up the same mapserv
> file
> on the localhost- works fine.
> I'm stumped... I'm begining to think that i have to start editing the code
> to
> produce a proper header?
> Quoting Steve Lime <steve.lime at dnr.state.mn.us>:
> > The setting for IMAGEPATH looks suspect. The way it's set mapserv will
> > be looking for a writable
> > directory in your cgi-bin directory. That's probably not what you want.
> > That parameter should
> > be full path and should have a trailing slash.
> > Steve
> > >>> <mapserv at dinequest.us> 03/27/03 12:34PM >>>
> > hello everyone,
> > I'm hoping someone can help me by suggesting some options in hopes that
> > i can
> > get mapserv working on my server. I layed out my steps so that it can
> > be easier
> > to follow:
> > - I have a redhat linux box (2.4.18-3 i386) which i've built a static
> > library
> > mapserv on. (ran mapserv -v and it listed correct supports)
> > - I uploaded it to my server's cgi-bin (which is a redhat 2.4.19 i386)
> > - set chmod 755 on mapserv
> > - set up demo.map mapfile correctly in the cgi-bin
> > - uploaded proper data in cgi-bin under the "data" directory
> > - ran from browser: http://<my location>/cgi-bin/mapserv?
> > map=demo.map&VERSION=1.1.0&REQUEST=GetMap&BBOX=-83.81,41.25,-81.80,42.79
> > *recieved internal error ("premature end of script headers" in log)
> > - renamed mapserv to mapserv.cgi
> > i assume that this is not a mapfile issue, but here is my mapfile
> > anyway:
> > NAME DEMO
> > WEB
> > IMAGEPATH "data"
> > IMAGEURL "http://www.dinequest.us/data"
> > END
> > END
> > UNITS DD
> > EXTENT -178 16 -66 74
> > SIZE 324 210
> > SHAPEPATH "data"
> > LAYER
> > NAME "states"
> > DATA dtl_st
> > STATUS DEFAULT
> > TYPE POLYGON
> > CLASS
> > COLOR 250 247 222
> > END # end of class object
> > END # end of layer object
> > IMAGETYPE JPEG
> > IMAGEQUALITY 90
> > INTERLACE OFF
> > END # end of map file
> > I appreciate any other suggestions. You guys are the gurus and i would
> > be alot
> > farther behind if it weren't for you all. Thanks in advance -bp
> > Mapserver-users mailing list
> > Mapserver-users at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
