[Mapserver-users] msOpenSHPFile(): Unable to access file
woodbri at swoodbridge.com woodbri at swoodbridge.com
Sun Mar 30 08:25:44 EST 2003
Inna,
Check the file and directory permissions. They must be readable by
the apache process.
-Steve W.
On 30 Mar 2003 at 12:38, Inna Janssen wrote:
> Hi,
> mapserv is unable to access the data file. But I definitely set all
> paths correctly. The mapfile is the one from the tutorial, starting
> this way: --- NAME S1EX2 EXTENT -97.238976 41.619778 -82.122902
> 49.38562 SIZE 400 300 SHAPEPATH "/var/www/html/karte/data" LAYER #
> States
>   NAME "states"
>   DATA states_ugl
>   STATUS DEFAULT
> the shapepath is set correctly. I downloaded the states_ugl from
> http://terrasip.gis.umn.edu/terrasipProjects/tutorial35/data/states_ug
> l.shp I call mapserv directly by entering the url
> http://www.inna.de/cgi-bin/mapserv?map=/var/www/html/karte/karte.map&m
> ode=map Then I get: "msOpenSHPFile(): Unable to access file.
> (states_ugl) " I also tried it with relative paths, with ending slash,
> with adding .shp to states_ugl I also checked the file permission of
> states_ugl. Nothing helped.
> I use Redhat Linux 7.3
> Instead, the itasca demo does work!
> Does anyone has any idea ???
> Greetings,
> Inna
> ______________________________________________________________________
> ________ Die SMS direkt auf's Handy. - Die Blitz-SMS bei WEB.DE
> FreeMail http://freemail.web.de/features/?mc=021165
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
