[Mapserver-users] msOpenSHPFile(): Unable to access file
Inna Janssen
innaj at web.de
Sun Mar 30 05:38:59 EST 2003
mapserv is unable to access the data file. But I definitely set all paths
correctly.
The mapfile is the one from the tutorial, starting this way:
NAME S1EX2
EXTENT -97.238976 41.619778 -82.122902 49.38562
SIZE 400 300
SHAPEPATH "/var/www/html/karte/data"
LAYER # States
NAME "states"
DATA states_ugl
STATUS DEFAULT
the shapepath is set correctly. I downloaded the states_ugl from
http://terrasip.gis.umn.edu/terrasipProjects/tutorial35/data/states_ugl.shp
I call mapserv directly by entering the url
http://www.inna.de/cgi-bin/mapserv?map=/var/www/html/karte/karte.map&mode=map
Then I get: "msOpenSHPFile(): Unable to access file. (states_ugl) "
I also tried it with relative paths, with ending slash, with adding .shp to states_ugl
I also checked the file permission of states_ugl.
Nothing helped.
I use Redhat Linux 7.3
Instead, the itasca demo does work!
Does anyone has any idea ???
Greetings,
Inna
______________________________________________________________________________
Die SMS direkt auf's Handy. - Die Blitz-SMS bei WEB.DE FreeMail
http://freemail.web.de/features/?mc=021165
