[Mapserver-users] Projection in Mapserver Problem
Hermie
hartr at 3logix.com.au
Wed May 7 19:57:34 EDT 2003
This is a multi-part message in MIME format.
------=_NextPart_000_0005_01C31548.3F6F6740
Content-Type: text/plain;
charset="iso-8859-1"
Content-Transfer-Encoding: 7bit
I have set up a map file using utm projection, RASTER layer using utm
projection and am trying to render points based on received lat/long from a
GPS device. The locations displayed are way off (PROJECTION object for
lat/long was added to the layer), however if I take the lat/long coordinates
received and convert them to utm coordinates with a conversion tool I have
and they are pretty close (not exact).
The other anomaly I struck was when I tried to convert all the projections
to lat/long firstly the EXTENT was set to lat long (based on the converted
utm coordinates) and the x,y of RASTER layer displayed in the centre even
though the anchor point x,y was the same in both the MAP EXTENT and the .wld
file (I did add utm projection object to the raster layer).
I also tried the point project API and the locations are still off, the
variation appears to be about 50km North and about 10km west of the real
location.
Any help/advise would be appreciated.
//Wld File
13.901760889712696941612604263207
0.0000000000
0.0000000000
-13.899920571882446386020651310564
480000
7000000
//Map File
MAP
NAME BRISBANE
STATUS ON
EXTENT 480000.00 7000000.00 540000.00 6930000.00
UNITS METERS
SHAPEPATH "data"
SIZE 500 500
PROJECTION
"proj=utm"
"zone=56"
"south"
"ellps=aust_SA"
"towgs84=-133,-48,148,0,0,0,0"
"units=m"
"no_defs"
END
SYMBOL
NAME 'circle'
IMAGE './data/trucks.gif'
TYPE pixmap
END
REFERENCE
IMAGE graphics/reference.gif
SIZE 120 140
STATUS ON
EXTENT 480000.00 6930000.00 540000.00 7000000.00
END
LAYER
NAME mainmap
DATA brisbane.tiff
TYPE Raster
STATUS ON
END
LAYER
NAME trucks
STATUS DEFAULT
TYPE POINT
PROJECTION
proj=longlat
ellps=aust_SA
no_defs
END
CLASS
NAME "clstrucks"
SYMBOL 'circle'
MAXSIZE 200
END
END
SCALEBAR
IMAGECOLOR 255 255 255
LABEL
COLOR 255 255 255
SIZE tiny
END
STYLE 1
SIZE 80 2
COLOR 255 255 255
UNITS KILOMETERS
INTERVALS 1
TRANSPARENT FALSE
STATUS TRUE
END
END
Hart Runge
3Logix Pty Ltd
Delivering Total Logistic Solutions
Ph. 1300 727 100
Fax 1300 727 101
Mobile 0402 794198
mailto:hartr at 3Logix.com.au <mailto:hartrung at remede.com.au>
http://www.3Logix.com.au <http://www.remede.com.au/>
This transmission is for the intended addressee only. If you have received
this transmission in error, please delete the mail and notify the sender.
The Contents of this e-mail are the opinion of the writer only and are not
endorsed by 3Logix Pty Ltd unless expressly stated otherwise.
Content-Type: text/html;
Content-Transfer-Encoding: quoted-printable
<html xmlns:o=3D"urn:schemas-microsoft-com:office:office" =
xmlns:w=3D"urn:schemas-microsoft-com:office:word" =
xmlns=3D"http://www.w3.org/TR/REC-html40">
<head>
<meta http-equiv=3DContent-Type content=3D"text/html; =
charset=3Diso-8859-1">
<meta name=3DProgId content=3DWord.Document>
<meta name=3DGenerator content=3D"Microsoft Word 9">
<meta name=3DOriginator content=3D"Microsoft Word 9">
<link rel=3DFile-List href=3D"cid:filelist.xml at 01C31548.3ECF2FA0">
<!--[if gte mso 9]><xml>
<o:OfficeDocumentSettings>
<o:DoNotRelyOnCSS/>
</o:OfficeDocumentSettings>
</xml><![endif]--><!--[if gte mso 9]><xml>
<w:WordDocument>
<w:View>Normal</w:View>
<w:Zoom>0</w:Zoom>
<w:DocumentKind>DocumentEmail</w:DocumentKind>
<w:EnvelopeVis/>
</w:WordDocument>
</xml><![endif]-->
<style>
/* Font Definitions */
@font-face
{font-family:"Book Antiqua";
panose-1:2 4 6 2 5 3 5 3 3 4;
mso-font-charset:0;
mso-generic-font-family:roman;
mso-font-pitch:variable;
mso-font-signature:647 0 0 0 159 0;}
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{mso-style-parent:"";
margin:0in;
margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:12.0pt;
font-family:"Times New Roman";
mso-fareast-font-family:"Times New Roman";}
a:link, span.MsoHyperlink
{color:blue;
text-decoration:underline;
text-underline:single;}
a:visited, span.MsoHyperlinkFollowed
{color:purple;
p.MsoAutoSig, li.MsoAutoSig, div.MsoAutoSig
{margin:0in;
font-size:12.0pt;
span.EmailStyle15
{mso-style-type:personal-compose;
mso-ansi-font-size:10.0pt;
mso-ascii-font-family:Arial;
mso-hansi-font-family:Arial;
mso-bidi-font-family:Arial;
color:black;}
@page Section1
{size:8.5in 11.0in;
margin:1.0in 1.25in 1.0in 1.25in;
mso-header-margin:.5in;
mso-footer-margin:.5in;
mso-paper-source:0;}
div.Section1
{page:Section1;}
</style>
</head>
<body lang=3DEN-AU link=3Dblue vlink=3Dpurple =
style=3D'tab-interval:.5in'>
<div class=3DSection1>
<p class=3DMsoNormal><span class=3DEmailStyle15><font size=3D2 =
color=3Dblack
face=3DArial><span =
style=3D'font-size:10.0pt;mso-bidi-font-size:12.0pt;font-family:
Arial'>Hi,<o:p></o:p></span></font></span></p>
color=3Dblack
Arial'><![if =
!supportEmptyParas]> <![endif]><o:p></o:p></span></font></span></p>
color=3Dblack
Arial'>I have set up a map file using utm projection, RASTER layer using =
utm
projection and am trying to render points based on received lat/long =
from a GPS
device. The locations displayed are way off (PROJECTION object for =
lat/long was
added to the layer), however if I take the lat/long coordinates received =
and
convert them to utm coordinates with a conversion tool I have and they =
are
pretty close (not exact).<o:p></o:p></span></font></span></p>
color=3Dblack
Arial'><![if =
color=3Dblack
Arial'>The other anomaly I struck was when I tried to convert all the
projections to lat/long firstly the EXTENT was set to lat long (based on =
the
converted utm coordinates) and the x,y of RASTER layer displayed in the =
centre
even though the anchor point x,y was the same in both the MAP EXTENT and =
the .wld
file (I did add utm projection object to the raster =
layer).<o:p></o:p></span></font></span></p>
color=3Dblack
Arial'><![if =
color=3Dblack
Arial'>I also tried the point project API and the locations are still =
off, the
location.<o:p></o:p></span></font></span></p>
color=3Dblack
Arial'><![if =
color=3Dblack
Arial'>Any help/advise would be =
appreciated.<o:p></o:p></span></font></span></p>
color=3Dblack
Arial'><![if =
color=3Dblack
Arial'>//Wld File<o:p></o:p></span></font></span></p>
color=3Dblack
Arial'>13.901760889712696941612604263207<o:p></o:p></span></font></span><=
/p>
color=3Dblack
Arial'>0.0000000000<o:p></o:p></span></font></span></p>
color=3Dblack
color=3Dblack
Arial'>-13.899920571882446386020651310564<o:p></o:p></span></font></span>=
</p>
color=3Dblack
Arial'>480000<o:p></o:p></span></font></span></p>
color=3Dblack
Arial'>7000000<o:p></o:p></span></font></span></p>
color=3Dblack
Arial'><![if =
color=3Dblack
Arial'>//Map File<o:p></o:p></span></font></span></p>
color=3Dblack
Arial'>MAP<o:p></o:p></span></font></span></p>
color=3Dblack
Arial'>NAME BRISBANE<o:p></o:p></span></font></span></p>
color=3Dblack
Arial'>STATUS ON<o:p></o:p></span></font></span></p>
color=3Dblack
Arial'>EXTENT 480000.00 7000000.00 540000.00 =
6930000.00<o:p></o:p></span></font></span></p>
color=3Dblack
Arial'>UNITS METERS<o:p></o:p></span></font></span></p>
color=3Dblack
Arial'>SHAPEPATH "data"<o:p></o:p></span></font></span></p>
color=3Dblack
Arial'>SIZE 500 500<o:p></o:p></span></font></span></p>
color=3Dblack
Arial'><![if =
color=3Dblack
Arial'>PROJECTION<o:p></o:p></span></font></span></p>
color=3Dblack
Arial'><span style=3D"mso-spacerun: yes"> =
</span>"proj=3Dutm"<span
style=3D'mso-tab-count:1'> </span> =
color=3Dblack
</span>"zone=3D56"<o:p></o:p></span></font></span></p>
color=3Dblack
</span>"south"<o:p></o:p></span></font></span></p>
color=3Dblack
</span>"ellps=3Daust_SA"<o:p></o:p></span></font></span></p>
color=3Dblack
</span>"towgs84=3D-133,-48,148,0,0,0,0"<o:p></o:p></span></font=
></span></p>
color=3Dblack
</span>"units=3Dm"<o:p></o:p></span></font></span></p>
color=3Dblack
</span>"no_defs"<o:p></o:p></span></font></span></p>
color=3Dblack
Arial'>END<o:p></o:p></span></font></span></p>
color=3Dblack
Arial'><![if =
color=3Dblack
Arial'>SYMBOL<o:p></o:p></span></font></span></p>
color=3Dblack
Arial'><span style=3D"mso-spacerun: yes"> </span>NAME =
'circle'<o:p></o:p></span></font></span></p>
color=3Dblack
Arial'><span style=3D"mso-spacerun: yes"> </span>IMAGE =
'./data/trucks.gif'<o:p></o:p></span></font></span></p>
color=3Dblack
Arial'><span style=3D"mso-spacerun: yes"> </span>TYPE pixmap<span
</span><o:p></o:p></span></font></span></p>
color=3Dblack
color=3Dblack
Arial'><![if =
color=3Dblack
Arial'>REFERENCE<o:p></o:p></span></font></span></p>
color=3Dblack
graphics/reference.gif<span style=3D"mso-spacerun: yes"> =
color=3Dblack
Arial'><span style=3D"mso-spacerun: yes"> </span>SIZE 120 =
140<o:p></o:p></span></font></span></p>
color=3Dblack
Arial'><span style=3D"mso-spacerun: yes"> </span>STATUS =
color=3Dblack
Arial'><span style=3D"mso-spacerun: yes"> </span>EXTENT 480000.00
6930000.00 540000.00 7000000.00 <o:p></o:p></span></font></span></p>
color=3Dblack
color=3Dblack
Arial'><![if =
color=3Dblack
Arial'>LAYER<o:p></o:p></span></font></span></p>
color=3Dblack
mainmap<o:p></o:p></span></font></span></p>
color=3Dblack
Arial'><span style=3D"mso-spacerun: yes"> </span>DATA =
brisbane.tiff<o:p></o:p></span></font></span></p>
color=3Dblack
Arial'><span style=3D"mso-spacerun: yes"> </span>TYPE =
Raster<o:p></o:p></span></font></span></p>
color=3Dblack
color=3Dblack
color=3Dblack
Arial'><![if =
color=3Dblack
color=3Dblack
trucks<o:p></o:p></span></font></span></p>
color=3Dblack
</span>STATUS DEFAULT<o:p></o:p></span></font></span></p>
color=3Dblack
POINT<span style=3D"mso-spacerun: yes"> =
color=3Dblack
</span>PROJECTION<o:p></o:p></span></font></span></p>
color=3Dblack
</span>proj=3Dlonglat<o:p></o:p></span></font></span></p>
color=3Dblack
Arial'><span style=3D"mso-spacerun: yes"> </span><span
style=3D"mso-spacerun: yes"> </span><span style=3D"mso-spacerun:
yes"> </span><span style=3D"mso-spacerun: =
yes"> </span>ellps=3Daust_SA<o:p></o:p></span></font></span></p>
color=3Dblack
</span>no_defs<o:p></o:p></span></font></span></p>
color=3Dblack
</span>END<o:p></o:p></span></font></span></p>
color=3Dblack
</span>CLASS<o:p></o:p></span></font></span></p>
color=3Dblack
</span>NAME "clstrucks"<o:p></o:p></span></font></span></p>
color=3Dblack
</span>SYMBOL 'circle'<o:p></o:p></span></font></span></p>
color=3Dblack
style=3D"mso-spacerun: yes"> </span>MAXSIZE =
200<o:p></o:p></span></font></span></p>
color=3Dblack
color=3Dblack
color=3Dblack
Arial'><![if =
color=3Dblack
Arial'>SCALEBAR<o:p></o:p></span></font></span></p>
color=3Dblack
Arial'><span style=3D"mso-spacerun: yes"> </span>IMAGECOLOR 255 =
255 255<o:p></o:p></span></font></span></p>
color=3Dblack
</span>LABEL<o:p></o:p></span></font></span></p>
color=3Dblack
Arial'><span style=3D"mso-spacerun: yes"> </span>COLOR =
255 255
color=3Dblack
Arial'><span style=3D"mso-spacerun: yes"> </span>SIZE =
tiny<span
color=3Dblack
color=3Dblack
Arial'><span style=3D"mso-spacerun: yes"> </span>STYLE =
1<o:p></o:p></span></font></span></p>
color=3Dblack
Arial'><span style=3D"mso-spacerun: yes"> </span>SIZE 80 =
2<o:p></o:p></span></font></span></p>
color=3Dblack
Arial'><span style=3D"mso-spacerun: yes"> </span>COLOR 255 255 =
color=3Dblack
Arial'><span style=3D"mso-spacerun: yes"> </span>UNITS =
KILOMETERS<o:p></o:p></span></font></span></p>
color=3Dblack
Arial'><span style=3D"mso-spacerun: yes"> </span>INTERVALS =
color=3Dblack
Arial'><span style=3D"mso-spacerun: yes"> </span>TRANSPARENT =
FALSE<o:p></o:p></span></font></span></p>
color=3Dblack
TRUE<o:p></o:p></span></font></span></p>
color=3Dblack
color=3Dblack
Arial'><![if =
color=3Dblack
color=3Dblack
Arial'><![if =
<p class=3DMsoNormal><!--[if supportFields]><font color=3Dblack><span=20
style=3D'color:black'><span =
style=3D'mso-element:field-begin'></span><span=20
style=3D"mso-spacerun: yes"> </span>AUTOTEXTLIST \s "E-mail=20
Signature" <span =
style=3D'mso-element:field-separator'></span></span></font><![endif]--><f=
ont
size=3D2 color=3Dblack face=3DArial><span =
12.0pt;font-family:Arial;color:black'>Hart Runge</span></font><font =
size=3D2
font-family:Arial;color:black;mso-color-alt:windowtext'><o:p></o:p></span=
></font></p>
<p class=3DMsoNormal><b><i><font size=3D2 color=3Dblack face=3D"Book =
Antiqua"><span
style=3D'font-size:11.0pt;mso-bidi-font-size:12.0pt;font-family:"Book =
Antiqua";
mso-bidi-font-family:Arial;color:black;font-weight:bold;font-style:italic=
'>3Logix
Pty Ltd</span></font></i></b><b><i><font size=3D2 color=3Dblack =
face=3D"Book Antiqua"><span
Antiqua";
mso-bidi-font-family:Arial;color:black;mso-color-alt:windowtext;font-weig=
ht:
bold;font-style:italic'><o:p></o:p></span></font></i></b></p>
Antiqua"><span
Antiqua";
'>Delivering
Total Logistic Solutions</span></font></i></b><b><i><font size=3D2 =
color=3Dblack
Arial;color:black;mso-color-alt:windowtext;font-weight:bold;font-style:it=
<p class=3DMsoNormal><font size=3D2 color=3Dblack face=3DArial><span =
style=3D'font-size:
10.0pt;mso-bidi-font-size:12.0pt;font-family:Arial;color:black'>Ph. 1300 =
727
100</span></font><font size=3D2 color=3Dblack face=3DArial><span =
style=3D'font-size:
10.0pt;mso-bidi-font-size:12.0pt;font-family:Arial;color:black;mso-color-=
alt:
windowtext'><o:p></o:p></span></font></p>
style=3D'font-size:
10.0pt;mso-bidi-font-size:12.0pt;font-family:Arial;color:black'>Fax 1300 =
727
101</span></font><font size=3D2 color=3Dblack face=3DArial><span =
style=3D'font-size:
alt:
style=3D'font-size:
10.0pt;mso-bidi-font-size:12.0pt;font-family:Arial;color:black'>Mobile =
0402
794198</span></font><font size=3D2 color=3Dblack face=3DArial><span =
style=3D'font-size:
alt:
style=3D'font-size:
10.0pt;mso-bidi-font-size:12.0pt;font-family:Arial;color:black'><a
href=3D"mailto:hartrung at remede.com.au"><font size=3D3 face=3D"Times New =
Roman"><span
style=3D'font-size:12.0pt;font-family:"Times New =
Roman"'>mailto:hartr at 3Logix.com.au</span></font></a></span></font><font
12.0pt;font-family:Arial;color:black;mso-color-alt:windowtext'><o:p></o:p=
></span></font></p>
style=3D'font-size:
href=3D"http://www.remede.com.au/"><font size=3D3 face=3D"Times New =
Roman"><span
Roman"'>http://www.3Logix.com.au</span></font></a></span></font><font
></span></font></p>
<p class=3DMsoNormal><font size=3D3 color=3Dblack face=3D"Times New =
Roman"><span
style=3D'font-size:12.0pt;color:black'><![if =
!supportEmptyParas]> <![endif]></span></font><font
color=3Dblack><span =
style=3D'color:black;mso-color-alt:windowtext'><o:p></o:p></span></font><=
/p>
Roman"><span
style=3D'font-size:12.0pt;color:black'>This transmission is for the =
intended
addressee only. If you have received</span></font><font =
color=3Dblack><span
/p>
Roman"><span
style=3D'font-size:12.0pt;color:black'>this transmission in error, =
please delete
the mail and notify the sender.</span></font><font color=3Dblack><span
/p>
Roman"><span
style=3D'font-size:12.0pt;color:black'>The Contents of this e-mail are =
the
opinion of the writer only and are not</span></font><font =
color=3Dblack><span
/p>
Roman"><span
style=3D'font-size:12.0pt;color:black'>endorsed by 3Logix Pty Ltd unless
expressly stated otherwise.</span></font><font color=3Dblack><span
/p>
style=3D'mso-element:field-end'></span></span></font><![endif]--><font
color=3Dblack><span style=3D'color:black'><![if =
/p>
</div>
</body>
</html>
------=_NextPart_000_0005_01C31548.3F6F6740--
