[Mapserver-users] Combining images from several mapfiles
Jan Hartmann
jhart at frw.uva.nl
Fri May 16 08:46:04 EDT 2003
And as a final remark (I am not very coherent, but the weekend
approaches), combining maps from several mapfiles is an interesting
option when using different servers. The browser processes all image
requests in parallel, i.e. it sends the first, and immediately proceeds
to the second without waiting for the image to arrive. With one server
this makes no difference, as both images have to be processed one after
another, but different servers can work in parallel. There is some
network delay when de images are sent back to the browser, but MapServer
images are not very large as a rule. I have been doing this on the
Beowulf cluster of this U. for some time now; the cluster is not
accessible to the general public (yet), but I will show the results at
the User's Meeting. Essentially this is a WMS/WFS like operation, but
with the full power of MapServer to create individual layers.
Jan
Jan Hartmann wrote:
> Oh, and by the way, you can even set tranparency of the different images
> within the browser in the style items:
> Mozilla: <img style="-moz-Opacity:0.5">
> IE <img style="filter:alpha(opacity=50)">
> I think both browsers will accept a combined style item:
> <img style="-moz-opacity:0.5;filter:alpha(opacity=50)">
> Of course, this way you are doing *two* Mapserver requests for one map,
> which requires much more server processing than one map with two layers.
> Jan
> One solution would be to use stacked images in the browser:
> <img id=i1 style="position:absolute;left:0;top:0">
> <img id=i2 style="position:absolute;left:0;top:0">
> <script>
> img1 = document.getElementById("i1")
> img2 = document.getElementById("i2")
> img1.src = "http://.../mapserv?map=first.map&mode=map"
> img2.src = "http://.../mapserv?map=second.map&mode=map"
> </script>
> Of course img2 has to be transparent for img1 to show through.
> Marco Ferrari wrote:
>> Hi,
>> Is it possible to display more than map files in the same browser window?
>> I am using a map file with many layers and so I thought to use more
>> than map files.
>> According to you, is correct?
>> Thanks.
>> Mapserver-users mailing list
>> Mapserver-users at lists.gis.umn.edu
>> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
