[Mapserver-users] known issue: no results with QueryByPoint (Mapserver 3.7 PHP mapscript)
Michael Härtel
mhaerte1 at gwdg.de
Wed May 21 07:41:33 EDT 2003
Hello All!
There are many references to articles about the problem that no results
are returned by QueryByPoint.
i' ve read all of them but i still can't figure out why i get no results.
This is what i have:
1.) A Query Layer ($querylayer) with a template file:
object(layer)(35) { ["_handle_"]=> resource(50) of type (layerObj)
["_map_handle_"]=> resource(1) of type (mapObj) ["numclasses"]=>
int(0) ["index"]=> int(7) ["status"]=> int(0) ["classitem"]=>
string(0) "" ["name"]=> string(11) "WRS-2_frame" ["group"]=> string(0)
"" ["data"]=> string(9) "wrs2/wrs2" ["type"]=> int(2) ["tolerance"]=>
float(3) ["toleranceunits"]=> int(6) ["symbolscale"]=> float(-1)
["minscale"]=> float(-1) ["maxscale"]=> float(-1) ["labelminscale"]=>
float(-1) ["labelmaxscale"]=> float(-1) ["maxfeatures"]=> int(-1)
["transform"]=> int(1) ["labelcache"]=> int(1) ["postlabelcache"]=>
int(0) ["labelitem"]=> string(0) "" ["labelsizeitem"]=> string(0) ""
["labelangleitem"]=> string(0) "" ["tileitem"]=> string(8) "location"
["tileindex"]=> string(0) "" ["header"]=> string(32)
"H:\_webroot_\mapserv_header.html" ["footer"]=> string(32)
"H:\_webroot_\mapserv_footer.html" ["connection"]=> string(0) ""
["connectiontype"]=> int(1) ["filteritem"]=> string(0) ""
["template"]=> string(40) "H:\_webroot_\mapserv_query_template.html"
["transparency"]=> int(0) ["styleitem"]=> string(0) "" ["offsite"]=>
object(color)(4) { ["_handle_"]=> resource(51) of type (Unknown)
["red"]=> int(-1) ["green"]=> int(-1) ["blue"]=> int(-1) } }
2.) A Point Object with geographic coordinates:
object(point)(4) { ["_handle_"]=> resource(52) of type (Unknown)
["x"]=> float(9.85) ["y"]=> float(50.9) ["m"]=> float(50.9) }
3.) A call to Query function (with tolerance set in map file):
$query=$querylayer->QueryByPoint($my_point,MS_MULTIPLE,-1);
4. The entry of the query-layer in the map file:
LAYER #wrs2
NAME "WRS-2_frame"
PROJECTION
proj=longlat
ellps=WGS84
datum=WGS84
no_defs
END
DATA "wrs2/wrs2"
STATUS OFF
TYPE POLYGON
TOLERANCEUNITS kilometers
TOLERANCE 5
DUMP TRUE
HEADER "H:\_webroot_\mapserv_header.html"
TEMPLATE "H:\_webroot_\mapserv_query_template.html"
FOOTER "H:\_webroot_\mapserv_footer.html"
END # layer wrs2
4.) The map i use is a world map with these parameters:
EXTENT -180.000000 -90.000000 180.000000 90.000000
SIZE 600 300
UNITS DD
PROJECTION
proj=longlat
ellps=WGS84
datum=WGS84
no_defs
END
What i get is the common error message:
"Warning: MapServer Error in msQueryByPoint(): No matching record(s) found"
The query layer extends over the whole map.
These actions were already performed without any change to the result:
1. changed tolerance to 1 in QueryByPoint function call
2. MS_SINGLE mode tried instead of MS_MULTIPLE
3. Pixel coordinates in Point object used instead of geographic coordinates
So what the **** am i doing wrong? Unfortunately i can´t find an example
of a template file where i could look how the results can be printed.
But i guess i need a result first and THEN there may occur errors
concerning a misconfiguration because of a missing/wrong template file.
Do i actually need a template file if i use mapserver 3.7 with
mapscript? Or is it only needed by the simple CGI version?
Thanks for any reply, i'm glad to know that there are some real freaks
out there :)
(im looking forward to a documentation about how to perform queries with
mapserver 3.7 and mapscript).
Michael Härtel
Georg-August University Goettingen
Department of Geography
Cartography, GIS & Remote Sensing Section
project Notebook University, Internet Map Service
Goldschmidtstr. 5 Tel.: +49 (0)551/39-12671
37077 Goettingen Fax : +49 (0)551/39-8020
http://www.geogr.uni-goettingen.de/kuf/
