[Mapserver-users] known issue: no results with QueryByPoint (Mapserver 3.7 PHP mapscript)
Eric Bridger eric at gomoos.org
Wed May 21 04:37:07 EDT 2003
On Wed, 2003-05-21 at 11:41, Michael Härtel wrote:
> Do i actually need a template file if i use mapserver 3.7 with
> mapscript? Or is it only needed by the simple CGI version?
You don't need the "actual" template file, but you do need the TEMPLATE
attribute set in the layer. E.g. TEMPLATE "dont_exist.html".  I'm not
sure if this is still true in 3.7
