[Mapserver-users] MapServer 3.5: Error Message
Randy James
rjames57 at yahoo.com
Thu Oct 2 12:17:26 EDT 2003
Hi
I found that the best way to get started was to download
the demo and get that running first. The demo has examples
of all the files you need.
Cheers
Randy
--- "McNeil, Todd W. (TMCNEIL)" <TMCNEIL at arinc.com> wrote:
> Hi All,
> I'm new to this list and new to using MapServer, but I
> was hoping to learn
> about it and possibly use it. I'm a GIS user,
> specifically with ESRI and
> MapInfo products and have used ArcIMS a little. Someone
> pointed me to
> MapServer because it willl use shapefiles natively to
> create maps and it's
> free. I downloaded version 3.5 and installed it using
> the instructions.
> Everything seems to be working so far. I've tested the
> CGI executable using
> the instructions: http://localhost/scripts/mapserv.exe
> <http://localhost/scripts/mapserv.exe> (localhost is not
> actually my
> machine name) and get this message:
> No query information to decode. QUERY_STRING not set.
> I also downloaded the Tutorial and have come across an
> error message that
> does not make sense to me. I am going through the 1st
> example of section 1
> of the tutorial. I use this URL to retrieve a map image:
http://tmcneil1/Scripts/mapserv.exe?map=e:/projects/tutorial35/s1/s1ex1.map&
> amp;mode=map
<http://tmcneil1/Scripts/mapserv.exe?map=e:/projects/tutorial35/s1/s1ex1.map
> &mode=map> , and the resulting error message is:
> mapserv(): Web application error. No template provided.
> I'm not sure what's going on or if I am just plain
> missing something. I
> have read that there are three files that I don't have,
> the application
> initialization html file (demo_init.html), the map file
> (demo.map), and the
> main html template file (demo.html). Where can I find
> these and will it
> make my MapServer work? Any help will be greatly
> appreciated.
> Thanks,
> Todd McNeil
> ARINC
> Annapolis, MD
> Tel: 410.266.2302 Email: tmcneil at arinc.com
> Fax: 410.573.3170 Web: http://www.arinc.com
> <http://www.arinc.com>
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
__________________________________
Do you Yahoo!?
The New Yahoo! Shopping - with improved product search
http://shopping.yahoo.com
