[Mapserver-users] installation
Randy James rjames57 at yahoo.com
Thu Oct 2 12:27:15 EDT 2003
Hi
Have you checked in /usr/local/lib if your compiled GD
yourself it would be in there, but if you are using a rpm
it is in /usr/lib
you may need to add the path to /usr/local/lib in your
ld.so.conf and run ldconfig
Cheers
Randy
--- Scott Ferguson <scottf at secr.com> wrote:
> after compiling the source code and creating the
> 'mapserv' file I received
> this message when typing the ./mapserv command at the
> prompt to test it:
> "./mapserv: error while loading shared libraries:
> libgd.so.2: cannot open
> shared object file: No such file or directory"
> I've already compiled these librabries GD, Proj, and
> Freetype with success.
> Although, the 'libgd.so.2' file was not in my GD
> directory.
> any ideas as to the problem??
> thanks
> Scott Ferguson
> GIS Manager
> Global Routing Technologies
> 636.449.3212
> scottf at secr.com
> www.grti.net
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
__________________________________
Do you Yahoo!?
The New Yahoo! Shopping - with improved product search
http://shopping.yahoo.com
