[Mapserver-users] installation
Till Adams
adams at terrestris.de
Thu Oct 2 12:44:33 EDT 2003
Scott,
I guess you have to re-read your ld.so.conf table, probably you'll find
it in /etc
There are two ways to go:
1. Edit the file ld.so.conf and add the line
/usr/lib
Then restart your server or run '/sbin/ldconfig'
2.
Run the command
'/sbin/ldconfig /usr/local'
(Both as 'root')
If you choose way 2 please remember, that you'll have to give this
command every time you restart your server.
Hope that's it, have a nice weekend (yes, we in germany have
bank-holiday tomorrow and I'm NOT going to work ...)
Till
Scott Ferguson schrieb:
> after compiling the source code and creating the 'mapserv' file I received
> this message when typing the ./mapserv command at the prompt to test it:
> "./mapserv: error while loading shared libraries: libgd.so.2: cannot open
> shared object file: No such file or directory"
> I've already compiled these librabries GD, Proj, and Freetype with success.
> Although, the 'libgd.so.2' file was not in my GD directory.
> any ideas as to the problem??
> thanks
> Scott Ferguson
> GIS Manager
> Global Routing Technologies
> 636.449.3212
> scottf at secr.com
> www.grti.net
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
***** Besuchen Sie uns auf der acqua alta *****
***** vom 24.-27. November in München *****
Dipl. Geogr. Till Adams
terrestris, Paulsen&Adams GbR
Siemensstr. 8 * 53121 Bonn
Tel.: 0228 962 899 52 * Fax.: 0228 962 899 57
info at terrestris.de * www.terrestris.de
