[Mapserver-users] Building GDAL with Xerces on Redhat 9
Paul Spencer spencer at dmsolutions.ca
Thu Oct 2 16:38:35 EDT 2003
Doug,
Frank will likely have a comment, but the last time I did this (a few
days ago on, on a RH9 box) I had to use 1.6.0.  The gdal configure was
./configure --with-xerces
after running configure/make/make install on xercesc ... which puts it
in /usr/local/
The build on this version of xercesc is slightly different from the
current build instructions on the apache web site because they changed
the directory structure slightly, but I think it was only one directory
different then everything else worked the same as the current build
instructions (too bad they don't include the build instructions with the
tarball!)
Cheers,
Paul
On Thu, 2003-10-02 at 15:55, Doug Cates wrote:
> Hi,
> I'm trying to build a development version of MapServer 4.1 with WFS
> SERVER support so I can test using complex filters. I'd use a Windows
> binary if one was available, but since it isn't, I'm trying to put it on
> a RH9 box here, the only Linux box that I have available.
> I can't seem to get GDAL to build with Xerces-C. I noticed a thread
> earlier this year about this that seemed to indicate that GDAL 1.1.8
> must be used with Xerces-C 1.6.0. Is that the only valid combination
> allowed, or has GDAL been updated to support newer versions of Xerces?
> An idea: The installation docs should have a version matrix, specifying
> the exact versions of all the supporting libraries that should be used
> when building a specific version of MapServer.
> Does anyone have any tips on installing this? Would anytone be willing
> to look at my installation logs to see if anything jumps out at them?
> Regards,
> Doug
