[Mapserver-users] help needed
Christopher R. Thorne
thorne at dmsolutions.ca
Mon Oct 6 09:13:47 EDT 2003
Ronny,
Yes, the error message is a little ambiguous. From your layer
description I am assuming that you are using php_mapscript_36.dll
If you were using php_mapscript_40.dll or higher you will need a STYLE
object within the CLASS Object to hold your styling parameters
eg.
CLASS
EXPRESSION 'Nakuru'
STYLE
OUTLINECOLOR 128 128 128
COLOR 225 225 185
END
END
I have a question, I noticed that you have a Metadata Object with WMS
variables in it. Are you trying to connect to a WMS Server? If so, you
do not have a Connection Object, that contains the location of the data
you wish to display.
If it is local data you are using please make sure that path to your
SHAPEPATH in your Main MAP object is defined correctly, with respect to
the your DATA object found in this LAYER.
One last comment, I notice also that the path to your layer is not in quotes
DATA nakuru_region
should be:
DATA "nakuru_region"
I am not sure if this is the issue, but it is good practice to place
quotes around the strings you will be passing in your mapfile.
Thanks
Chris
ronny wrote:
> am trying to draw a map but am getting:
> msDrawMap(): Image handling error. Failed to draw
> layer named 'Nakuru_region'.
> i sincerely don't know what that means since am very
> new to maps drawing and mapserver!
> the layer is as follows:
> LAYER
> NAME Nakuru_region
> TYPE POINT
> STATUS DEFAULT
> DATA nakuru_region
> CLASSITEM 'cty_name'
> CLASS
> EXPRESSION 'Nakuru'
> COLOR 225 225 185
> END
> CLASS # every other towns in the region
> EXPRESSION /./
> COLOR 255 255 255
> END
> METADATA
> WMS_TITLE "Nakuru Towns"
> WMS_ABSTRACT "Nakuru Region shapfile."
> WMS_SRS "EPSG:26915"
> END
> END
> am on redhat linux 8.0
> mapserver 4.0
> ronny
> __________________________________
> Do you Yahoo!?
> The New Yahoo! Shopping - with improved product search
> http://shopping.yahoo.com
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
GIS Specialist,
DM Solutions Group Inc.
http://www.dmsolutions.ca
email: thorne at dmsolutions.ca
Phone: (613) 565-5056 ext.22
Fax : (613) 565-0925
