[Mapserver-users] Interlaced Reference
Vladimir Guzmán vguzman at maintask.com
Mon Oct 6 20:34:42 EDT 2003
Hello again.
I'm trying to use fpdf to get a "printable" map with phpmapscript.
Everything is fine, except that when I try to generate the Reference
Map, I get the following error:
*FPDF error: *Interlacing not supported:
/usr/local/apache/htdocs/tmp/MS_CTzMgP.png
This is because phpmapscript is producing an interlaced png, and FPDF
can't handle it.
But I have the following in my .map file:
OUTPUTFORMAT
   NAME png
   MIMETYPE "image/png"
   DRIVER "GD/PNG"
   FORMATOPTION "INTERLACE=OFF"
END
# Start of reference map
REFERENCE
 IMAGE "/usr/local/apache/htdocs/sig_curaduria/graphics/reference7.png"
   EXTENT 983737 984000 1007778 1026000
 SIZE 183 320
 STATUS ON
 COLOR -1 -1 -1
 OUTLINECOLOR 255 0 0
END
And it works perfect for the legend, the scale and the map itself.
The file /usr/local/apache/htdocs/sig_curaduria/graphics/reference7.png
is not interlaced.
My phpmapscript configuration:
MapServer Version     MapServer version 4.0-beta1 OUTPUT=PNG OUTPUT=JPEG
OUTPUT=WBMP OUTPUT=SWF SUPPORTS=PROJ SUPPORTS=FREETYPE
SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER INPUT=OGR
INPUT=GDAL INPUT=SHAPEFILE
PHP MapScript Version     ($Revision: 1.168 $ $Date: 2003/06/04 17:57:12 $)
Any hints?
Thanks a lot,
Vladimir Ilich Guzmán R.
http://www.maintask.com
