[Mapserver-users] Determining Shapefile EXTENT
Edward Waithaka
e_talis at yahoo.com
Tue Oct 7 10:57:49 EDT 2003
--0-1827529903-1065538669=:74591
Content-Type: text/plain; charset=us-ascii
I have managed to download some shapefiles, when I try to load a mapfile, I get a blank image. For one, I don't know which EXTENT to use and again I don't have ArcView (can't afford) to determine the shapefile's Extent. Is there another way of determining the extent of a shapefile without ArcView? The shapefiles I have downloaded come with Word Docs describing the data a little bit e.g
Additional attribute information
Shape: Internally generated by Arc/infoArea Internally generated by Arc/info
Perimeter: Internally generated by Arc/info
Town_name: Name of the town represented by the points Unique identification for each town class. The towns have been classified into 6 categories namely:
(1) Municipality (2) Township/Town (3) Trading center (4) Market center
(6) Lodges/camps (11) City
Town type: Class in which the particular towns fall
Layer Characteristics
Projection: Geographic
Theme: Administrative
Layer type: Arc View shape
Feature type: Point
Can anyone translate this for me? (atleast 'point' I can use e.g TYPE POINT in the mapfile ...)
Thank you,
Edward.
Do you Yahoo!?
The New Yahoo! Shopping - with improved product search
Content-Type: text/html; charset=us-ascii
<DIV>From: MS Newbie</DIV>
<DIV>I have managed to download some shapefiles, when I try to load a mapfile, I get a blank image. For one, I don't know which EXTENT to use and again I don't have ArcView (can't afford) to determine the shapefile's Extent. Is there another way of determining the extent of a shapefile without ArcView? The shapefiles I have downloaded come with Word Docs describing the data a little bit e.g</DIV>
<DIV> </DIV>
<DIV>----------------------------------------------------------------------------------</DIV>
<DIV> Additional attribute information<SPAN style="FONT-SIZE: 12pt; LINE-HEIGHT: 150%; mso-bidi-font-size: 10.0pt; mso-bidi-font-weight: bold"><BR><FONT size=2>Shape: <SPAN style="mso-tab-count: 1"> </SPAN>Internally generated by Arc/info</SPAN<BR>Area </FONT></SPAN><SPAN style="mso-tab-count: 1"> </SPAN>Internally generated by Arc/info</SPAN><SPAN style="FONT-SIZE: 12pt; LINE-HEIGHT: 150%; mso-bidi-font-size: 10.0pt; mso-bidi-font-weight: bold"><BR><FONT size=2>Perimeter:<SPAN style="mso-spacerun: yes"> </SPAN><SPAN style="mso-tab-count: 1"> </SPAN>Internally generated by Arc/info</FONT></SPAN><SPAN style="FONT-SIZE: 12pt; LINE-HEIGHT: 150%; mso-bidi-font-size: 10.0pt; mso-bidi-font-weight: bold"><BR><FONT size=2>Town_name:<SPAN style="mso-spacerun: yes"> </SPAN><SPAN
style="mso-tab-count: 1"> </SPAN>Name of the town represented by the points <SPAN style="mso-tab-count: 1"> </SPAN>Unique identification for each town class. The towns have been classified into 6 categories namely:</FONT></FONT></SPAN><SPAN style="FONT-SIZE: 12pt; LINE-HEIGHT: 150%; mso-bidi-font-size: 10.0pt; mso-bidi-font-weight: bold"><SPAN style="mso-tab-count: 1"><BR><FONT size=2> </FONT></SPAN><FONT size=2>(1) </FONT></SPAN><FONT size=2><?xml:namespace prefix = st1 ns = "urn:schemas-microsoft-com:office:smarttags" /><st1:place><st1:PlaceType><SPAN style="FONT-SIZE: 12pt; LINE-HEIGHT: 150%; mso-bidi-font-size: 10.0pt; mso-bidi-font-weight: bold">Municipality</SPAN></st1:PlaceType><SPAN style="FONT-SIZE: 12pt; LINE-HEIGHT: 150%; mso-bidi-font-size: 10.0pt; mso-bidi-font-weight: bold"> </SPAN><st1:PlaceName><SPAN style="FONT-SIZE: 12pt; LINE-HEIGHT: 150%; mso-bidi-font-size: 10.0pt; mso-bidi-font-weight:
bold">(2)</SPAN></st1:PlaceName><SPAN style="FONT-SIZE: 12pt; LINE-HEIGHT: 150%; mso-bidi-font-size: 10.0pt; mso-bidi-font-weight: bold"> </SPAN><st1:PlaceType><SPAN style="FONT-SIZE: 12pt; LINE-HEIGHT: 150%; mso-bidi-font-size: 10.0pt; mso-bidi-font-weight: bold">Township</SPAN></st1:PlaceType></st1:place><SPAN style="FONT-SIZE: 12pt; LINE-HEIGHT: 150%; mso-bidi-font-size: 10.0pt; mso-bidi-font-weight: bold">/Town (3) Trading center (4) Market center</SPAN><SPAN style="FONT-SIZE: 12pt; LINE-HEIGHT: 150%; mso-bidi-font-size: 10.0pt; mso-bidi-font-weight: bold"></FONT><BR><FONT size=2>(6) Lodges/camps (11) City</FONT></SPAN><SPAN style="FONT-SIZE: 12pt; LINE-HEIGHT: 150%; mso-bidi-font-size: 10.0pt; mso-bidi-font-weight: bold"><BR><FONT size=2>Town type:<SPAN style="mso-spacerun: yes"> </SPAN><SPAN style="mso-tab-count: 1"> </SPAN>Class in which the particular towns fall</FONT></SPAN><BR>Layer Characteristics<SPAN style="FONT-SIZE: 12pt; LINE-HEIGHT:
150%; mso-bidi-font-size: 10.0pt; mso-bidi-font-weight: bold"><BR><FONT size=2>Projection:<SPAN style="mso-tab-count: 1"> </SPAN>Geographic</FONT></SPAN><SPAN style="FONT-SIZE: 12pt; LINE-HEIGHT: 150%; mso-bidi-font-size: 10.0pt; mso-bidi-font-weight: bold"><BR><FONT size=2>Theme:<SPAN style="mso-tab-count: 1"> </SPAN>Administrative</FONT></SPAN><SPAN style="FONT-SIZE: 12pt; LINE-HEIGHT: 150%; mso-bidi-font-size: 10.0pt; mso-bidi-font-weight: bold"><BR><FONT size=2>Layer type: <SPAN style="mso-tab-count: 1"> </SPAN>Arc View shape</FONT></SPAN><SPAN style="FONT-SIZE: 12pt; LINE-HEIGHT: 150%; mso-bidi-font-size: 10.0pt; mso-bidi-font-weight: bold"><BR><FONT size=2>Feature type:<SPAN style="mso-tab-count: 1"> </SPAN>Point</FONT></SPAN></DIV>
<DIV><FONT size=2><SPAN style="FONT-SIZE: 12pt; LINE-HEIGHT: 150%; mso-bidi-font-size: 10.0pt; mso-bidi-font-weight: bold">----------------------------------------------------------------------------------------------------</SPAN></FONT></DIV>
<DIV><FONT size=2><SPAN style="FONT-SIZE: 12pt; LINE-HEIGHT: 150%; mso-bidi-font-size: 10.0pt; mso-bidi-font-weight: bold">Can anyone translate this for me? (atleast 'point' I can use e.g TYPE POINT in the mapfile ...)</SPAN></FONT></DIV>
<DIV><FONT size=2><SPAN style="FONT-SIZE: 12pt; LINE-HEIGHT: 150%; mso-bidi-font-size: 10.0pt; mso-bidi-font-weight: bold">Thank you,</SPAN></FONT></DIV>
<DIV><FONT size=2><SPAN style="FONT-SIZE: 12pt; LINE-HEIGHT: 150%; mso-bidi-font-size: 10.0pt; mso-bidi-font-weight: bold">Edward.</SPAN></FONT></DIV><BR><BR><DIV><IMG style="WIDTH: 149px; HEIGHT: 42.99%" height="50%" src="http://www.geocities.com/e_talis/talis.jpg" width=125></DIV><p><hr SIZE=1>
Do you Yahoo!?<br>
<a href="http://shopping.yahoo.com/?__yltc=s%3A150000443%2Cd%3A22708228%2Cslk%3Atext%2Csec%3Amail">The New Yahoo! Shopping</a> - with improved product search
--0-1827529903-1065538669=:74591--
