[Mapserver-users] Mapserver 4 Makefile for VC
Stephen Clark stephen.clark at focus.ca
Wed Oct 8 13:23:58 EDT 2003
Could someone post their makefile.vc and nmake.opt files.
I would like a version that has the minimum set of options set whichI can
then modify.
thanks
Stephen
----- Original Message -----
To: "'Yewondwossen Assefa'" <assefa at dmsolutions.ca>
Cc: <mapserver-users at lists.gis.umn.edu>
Sent: Friday, September 19, 2003 8:03 AM
Subject: RE: [Mapserver-users] Mapserver 4 Makefile for VC
> Missed that when looking, but after careful examination saw this file.,
> Thanks all as always for your patience and time on this.
> Gayathri
> -----Original Message-----
> From: Yewondwossen Assefa [mailto:assefa at dmsolutions.ca]
> Sent: Thursday, September 18, 2003 9:26 PM
> To: Swaminathan, Gayathri
> Cc: mapserver-users at lists.gis.umn.edu
> Subject: Re: [Mapserver-users] Mapserver 4 Makefile for VC
> Hi There,
>   There are now 2 files involved in the process, makefile.vc and
> nmake.opt  where all the options are included. This separation makes
> things clearer and the option file can be used by sub projects like
> php/mapscript.
> All settings for necessary libraries + optional libraries are inside the
> nmake.opt.
> Later,
> Swaminathan, Gayathri wrote:
> > Hi all:
> > After being content with mapserver-3.6.5 for a long time now, I was
> > getting ready to compile mapserver 4.0 and test it.
> > There are several changes that I notice between mapserver-3.6.5 and
> > mapserver-4.0. The makefile.vc in the package shrinked. I assumed this
> > is not the One that I should be using and proceeded with alterations
> > to my old makefile.vc that came from mapserver-3.6.5
> > I was finally sucessful in building a mapserver with the following
> > enabled.
> > MapServer version 4.0 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ
> > INPUT=EPP L7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> > I need WMS server and WMS Client with this. I see that libcurl is
> > being used somehow and keep getting errors on the same.
> > Please, indicate to me the right corrections to makefile.vc (or) tell
> > me where am I going wrong in this process.
> > Thanks so much for your time on this.
> > Gayathri
> > Mapserver-users mailing list Mapserver-users at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> Assefa Yewondwossen
> Software Analyst
> Email: assefa at dmsolutions.ca
> http://www.dmsolutions.ca/
> Phone: (613) 565-5056 (ext 14)
> Fax:   (613) 565-0925
