[Mapserver-users] Help with ArcSDE Layer Connection/Data specification
Pryor, Clayton J
CJPRYOR at sandia.gov
Wed Oct 8 13:14:22 EDT 2003
I am struggling with getting my connection and data specifications right for
an ArcSDE (Oracle database) layer that I am trying to bring into my
MapServer application.
Here is the relevant data and code:
Relevant demo_init contents:
<form method=GET action="/cgi-bin/mapserv">
<input type="hidden" name="map"
value="/usr/local/apache2/htdocs/demoSNL/demo.map>
<input type="hidden" name="layer" value="nercsbrgnstatus">
<input type="hidden" name="program" value="/cgi-bin/mapserv">
<input type="hidden" name="map_web_imagepath"
value="/usr/local/apache2/htdocs/tmp/">
<input type="hidden" name="map_web_imageurl" value="/tmp/">
<center><input type="submit" value="Initialize"></center>
ArcSDE server information (per our ArcSDE/Oracle database manager):
host name: orca-wks-1
instance name: port:5151
database name: insistdb
ArcSDE database Structure (per ArcCatalog):
Database Connections
|-Connection to orca-wks-1
|-SDE.NorthAmerica
|-SDE.nercSubRegions
Map File Connection Definition:
NAME nercsbrgnstatus
CONNECTION "orca-wks-1,port:5151,insistdb,userid,userpwd"
CONNECTIONTYPE sde
Map File Data definitions and the results:
Definition 1:
DATA "SDE.nercSubRegions,shape"
Definition 1 Result:
Internal Server Error: (from apache web server log)
"Premature end of script headers: mapserv, referer:
http://.../demoSNL/demo_init.html"
Definition 1 Comments:
I understand that this error indicates that the mapserv
application ended in an error condition that was not passed back to the
caller.
Definition 2:
DATA "insistdb.SDE.nercSubRegions,shape"
Definition 2 Result:
Web page result: "MapServer Message msDrawMap():Image
handling error. Failed to draw layer named 'nercsubrgnstatus'.
msSDELayerOpen(): SDE error. SE_layer_get_infor(): Layer not found. (-20)"
Definition 2 Comments:
Searching the mapserver-users archives and the web turned up
little help for these messages. The closest I found was similar, but not
the same. It was an Oracle Spatial error that was apparently due to no
spatial index being created for the shape column.
General Comment:
Since the Connection information has been confirmed to be correct by
my ArcSDE/Oracle expert, my guess is that I am not correctly specifying the
layer. Trying different layer naming options generates either the error in
Definition 1 or the error in Definition 2.
Any suggestions from you the members of the mapserver-users community as to
how to proceed with this? Your help will be greatly appreciated.
Sincerely,
Clay Pryor
Clayton J. Pryor phone (505) 845-3557
Sandia National Laboratories
Critical Infrastructure Surety fax (505) 844-9641
PO Box 5800 MS 0451
Albuquerque NM 87185-0451 email cjpryor at sandia.gov
