[Mapserver-users] Tiling Tif Images
Eduardo Spremolla
edspremolla at Antel.com.uy
Thu Oct 9 08:30:46 EDT 2003
I find the gdaltindex in bin directory on OpenEV_FW_161.zip
if you can't find it in the web I may put mine on a web url for you.
LALO
El jue, 09 de 10 de 2003 a las 08:40, Stefan Schwarzer escribió:
> Ed,
> a) the images I have (100-500 MB) are not yet tiled; and I assume it
> would result in a better performance if they would be.
> b) the images form different layers; so each image should be tiled
> separately. And yes: "Or are you trying to divide each of those files
> into smaller rasters and then tile those back together?"
> b) I did not succeed in finding the gdaltindex file, which seems to be
> necessary to do the tiling of images.
> Stefan
> > Stefan
> > You dont really say what the problem is, and you dont say what
> > happened when you didnt succeed. For example, when you used
> > gdaltindex, what result did you expect and what result did you get?
> > First, do your several dozen raster images taken together form a
> > tiled data set? Or are you trying to divide each of those files
> > - Ed
> > Ed McNierney
> > President and Chief Mapmaker
> > TopoZone.com
> > ed at topozone.com
> > -----Original Message-----
> > From: Stefan Schwarzer [mailto:stefan.schwarzer at grid.unep.ch]
> > Sent: Thursday, October 09, 2003 7:11 AM
> > To: mapserver-users at lists.gis.umn.edu
> > Subject: [Mapserver-users] Tiling Tif Images
> > Hi list,
> > hmm, I think I read everything concerning the tiling of raster
> > images by now. But the best hint I've found was the following URL (
> > http://remotesensing.org/gdal/gdal_utilities.html ). I read as well
> > this document ( http://mapserver.gis.umn.edu/doc/raster-howto.html
> > ), but no solution in sight. I tried to find the gdaltindex (for
> > windows), but did not succeed. I have the OpenEV installed, but this
> > does not offer tiling.
> > Fact is: I have several dozens of raster images which are mostly
> > between 100 and 500 MB. So, would you recommend to do some tiling
> > with these sizes? If yes, what tool should I use?
> > Can someone give be a tip?
> > Thanks,
> > Stefan
> > _______________________________________
> > Stefan Schwarzer
> > Consultant on GEO
> > UNEP/DEWA/GRID-Geneva
> > Chemin des Anemones 11
> > CH - 1219 Chatelaine
> > Switzerland
> > Tel: (+41) 22.917.83.49
> > Fax: (+41) 22.917.80.29
> > Email: stefan.schwarzer at grid.unep.ch
> > Internet: http://geodata.grid.unep.ch/
> Stefan Schwarzer
> Consultant on GEO
> Switzerland
