[Mapserver-users] Mapserver 4 Makefile for VC
Swaminathan, Gayathri gayathri at ou.edu
Thu Oct 9 09:21:09 EDT 2003
Stephen,
The gdal error is coming because....you have forgot/dint comment the
following line in Makefile.vc
	"copy $(GDAL_DIR)\gdal.pdb ."
Comment the same by including a "#" in the beginning of the line.
On examining your nmake.opt, I see "c:\project" to be your working
directory...Is this correct? Are all the required libraries in here? Have
they been compiled before you proceeded to compile mapserver 4.0?
Cheers,
Gayathri
-----Original Message-----
From: Stephen Clark [mailto:stephen.clark at focus.ca]
Sent: Wednesday, October 08, 2003 1:32 PM
To: mapserver-users at lists.gis.umn.edu
Subject: Re: [Mapserver-users] Mapserver 4 Makefile for VC
I have included my makefile.vc and nmake.opt files as well as the compile
errors foer your consideration.
thanks,
Stephen
----- Original Message -----
To: "Swaminathan, Gayathri" <gayathri at ou.edu>; "'Yewondwossen Assefa'"
<assefa at dmsolutions.ca>
Cc: <mapserver-users at lists.gis.umn.edu>
Sent: Wednesday, October 08, 2003 10:23 AM
> Could someone post their makefile.vc and nmake.opt files.
> I would like a version that has the minimum set of options set whichI
> can then modify.
> thanks
> Stephen
> From: "Swaminathan, Gayathri" <gayathri at ou.edu>
> To: "'Yewondwossen Assefa'" <assefa at dmsolutions.ca>
> Sent: Friday, September 19, 2003 8:03 AM
> Subject: RE: [Mapserver-users] Mapserver 4 Makefile for VC
> > Missed that when looking, but after careful examination saw this
> > file.,
> > Thanks all as always for your patience and time on this.
> > Gayathri
> > From: Yewondwossen Assefa [mailto:assefa at dmsolutions.ca]
> > Sent: Thursday, September 18, 2003 9:26 PM
> > To: Swaminathan, Gayathri
> > Cc: mapserver-users at lists.gis.umn.edu
> > Hi There,
> >   There are now 2 files involved in the process, makefile.vc and
> > nmake.opt  where all the options are included. This separation makes
> > things clearer and the option file can be used by sub projects like
> > php/mapscript. All settings for necessary libraries + optional
> > libraries are inside the nmake.opt.
> > Later,
> > Swaminathan, Gayathri wrote:
> > > Hi all:
> > > After being content with mapserver-3.6.5 for a long time now, I
> > > was getting ready to compile mapserver 4.0 and test it.
> > > There are several changes that I notice between mapserver-3.6.5
> > > and mapserver-4.0. The makefile.vc in the package shrinked. I
> > > assumed this is not the One that I should be using and proceeded
> > > with alterations to my old makefile.vc that came from
> > > mapserver-3.6.5
> > > I was finally sucessful in building a mapserver with the following
> > > enabled.
> > > MapServer version 4.0 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> > > SUPPORTS=PROJ INPUT=EPP L7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL
> > > INPUT=SHAPEFILE
> > > I need WMS server and WMS Client with this. I see that libcurl is
> > > being used somehow and keep getting errors on the same.
> > > Please, indicate to me the right corrections to makefile.vc (or)
> > > tell me where am I going wrong in this process.
> > > Thanks so much for your time on this.
> > > Gayathri
> > > _______________________________________________
> > > Mapserver-users mailing list Mapserver-users at lists.gis.umn.edu
> > > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> > Assefa Yewondwossen
> > Software Analyst
> > Email: assefa at dmsolutions.ca
> > http://www.dmsolutions.ca/
> > Phone: (613) 565-5056 (ext 14)
> > Fax:   (613) 565-0925
