[Mapserver-users] Help with ArcSDE Layer
Connection/Dataspec ification - SOLVED!
Debbie Pagurek
pagurekd at agr.gc.ca
Thu Oct 9 12:03:19 EDT 2003
In order to render on attributes in another table, it is possible to set
up an Oracle VIEW that links the sde table to another oracle table, and
then in the mapfile, you point to this VIEW which has the combined
spatial data with other attribute info. We've done this for a protoype
agri-environmental indicator project.
Debbie
>>> "Pryor, Clayton J" <CJPRYOR at sandia.gov> 10/09/03 11:22AM >>>
I was able to get the layer to display by simplifying the associated
class.
For now, the class simply reads:
CLASS
OUTLINECOLOR 128 128 128
COLOR 0 255 0
END
Now that I know I have the ArcSDE interface working, I will continue
to
explore map file configuration options. Ultimately I would like to
have the
layer rendered based on attributes in another table but that is
another
thread.
Thanks again,
Clay
-----Original Message-----
Sent: Wednesday, October 08, 2003 4:09 PM
To: Pryor, Clayton J; 'mapserver-users at lists.gis.umn.edu'
Cc: InSIST
Subject: RE: [Mapserver-users] Help with ArcSDE Layer Connection/Data
specification
UPDATE!
Please forgive me for sending so many messages to the list. I have
truncated this one so as not to send so much redundant information but
still
retain relevant context.
The problem appears to be in the CLASSITEM/CLASS definition. The
problem
goes away when I comment these definitions out of the demo.map file.
Of
course, I can not see the layer either but this might help those of
you
trying to help me.
Tomorrow I will take a closer look at the CLASSITEM/CLASS
specifications to
see if I can get them right in this map file.
Thanks again,
Clay Pryor
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
